    Magic Mirror Default Weather Module
    6 Posts 2 Posters 2.9k Views 2 Watching
      bicolorbore586
      I’m just getting started with my magicmirror project, and having varying success.
      I’ve tried a couple of 3rd Party weather modules, but have settled on the default on as I like the simplicity of it.
      I’ve managed to configure it to show the current weather, but want to be able to view a forecast. However following the config instructions etc, changing it to a forecast just results in it appearing as loading on the screen.
      I’m using weatherbit.io as the provider and config.js is set as follows
      module: "weather",
                apibase: "https://api.weatherbit.io/v2.0",
                weatherEndpoint: "/current",
                apiKey: "MY API KEY"
               lat: MY LATITUDE
               lon: MY LONGITUDE
      weather.js
      defaults: {
                weatherProvider: "weatherbit"
                type: "current",
      this results in the correct display on magicmirror, however changing the endpoint to “/forecast”, “/daily” or “/forecast/daily” and the type to “forecast”, “daily” or “forecast/daily” just results in the loading icon.
      Can anyone shed some light please?
        sdetweil @bicolorbore586
        @bicolorbore586 do not edit the base source files, all configuration is done in config.js
        remove the API base and endpoint, don’t need to set them, the code does that
        set the provider and type
        (use the lastest release, 2.21, as we fixed a couple configs to always use the type)
        also set the initialLoadDelay:1
          bicolorbore586 @sdetweil
          @sdetweil Hi Sam, I’m probably not following this correctly, but I appear to be in a worse position than before in the fact that none of my modules now load.
          S 2 Replies Last reply Reply Quote 1
            @bicolorbore586 eh? sounds like a typo in the config
            in the MagicMirror folder do
            npm run config:check
              @bicolorbore586 mine looks like
              			module:"weather",
              			config:{
              				type:"current",
              				weatherProvider:"weatherbit",
              				lat:30.956,
              				lon:-97.435,
              				initialLoadDelay:1,
                                              units:'imperial',
              				apiKey:"your key"
              both type:“current” and type:“forecast” work
                @sdetweil all sorted now, I took the config out and put it back in fresh as I couldn’t work out where the typo/formatting error was. All tickety-boo now. Thanks for your help!
