    Electron Crashing after update to 2.21.0 with PM2
    10 Posts 2 Posters 3.3k Views 2 Watching
      pattanner92
      After updating my MagicMirror to version 2.21.0 it seems that Electron is crashing when using PM2 with the following error at crash (from pm2 logs):
      0|mm  | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTERM
      After the restart there seems to be a large number of errors thrown, though with a repeating pattern of the following:
      0|mm       | [30696:1006/101030.900201:ERROR:angle_platform_impl.cc(43)] renderergl_utils.cpp:2519 (CheckError): GL call functions->texStorage2D(ToGLenum(type), static_cast<GLsizei>(levels), texStorageFormat.internalFormat, size.width, size.height) generated error 0x00000505 in ../../third_party/angle/src/libANGLE/renderer/gl/TextureGL.cpp, setStorage:1052.
      0|mm       | [30696:1006/101030.901706:ERROR:shared_context_state.cc(811)] SharedContextState context lost via Skia OOM.
      0|mm       | [30696:1006/101030.903252:ERROR:gpu_service_impl.cc(990)] Exiting GPU process because some drivers can't recover from errors. GPU process will restart shortly.
      0|mm       | [19587:1006/101030.932806:ERROR:command_buffer_proxy_impl.cc(329)] GPU state invalid after WaitForGetOffsetInRange.
      0|mm       | [19587:1006/101030.940181:ERROR:gpu_process_host.cc(974)] GPU process exited unexpectedly: exit_code=8704
      0|mm       | MESA-LOADER: failed to retrieve device information
      Now, if I run MagicMirror by using npm start while in the ~/MagicMirror directory, it seems to stay up. Hoping someone has some insight on this. I can easily manually start the system, but would rather not have to every time.
      S 2 Replies Last reply Reply Quote 1
        sdetweil @pattanner92
        @pattanner92 how did you upgrade? manual or use my automated scripts?
        which os is this?
        show outout of
        uname -a
        lsb_release -a
          @pattanner92 also add
          export ELECTRON_DISABLE_GPU=1
          to the installers/mm.sh before the
          npm start line
          or wherever the mm comes from (in the pm2 logs output)
          my setup script use the mm.sh in the installers folder
            pattanner92 @sdetweil
            Output of first command is:
            Linux raspberrypi 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
            Output of second command is:
            No LSB modules are available.
            Distributor ID: Raspbian
            Description:    Raspbian GNU/Linux 10 (buster)
            Release:        10
            Codename:       buster
            I did so a manual upgrade. Though I typically do that without running into too many issues.
              Still seems to crash. This is how I have configured my pm2 start script:
              DISPLAY=:0 npm start
                @pattanner92 sorry two more
                node -v
                npm-v
                u are running on 32 bit buster, which is ok
                on some armv7l device, pi3, 4, or pi0w2
                  node v16.16.0
                  npm v8.11.0
                  I am running on a Raspberry Pi B3+
                    @pattanner92 can u try running my upgrade script with force instead of apply
                    see
                      EDIT: I was digging while cleaning up pm2 so it didn’t display my old script. I noticed that the mm.sh script in ~/MagicMirror/installers was indeed missing export ELECTRON_DISABLE_GPU=1. Adding that back to the script seems to keep it stable. Still wondering if this is an Electron version issue.
                      No dice. Here are the errors I am seeing in the logs - I pulled only the errors to see if I caught them all. Here is what I am seeing at the exit event:
                      0|mm  | [25978:1009/112505.776458:ERROR:zygote_communication_linux.cc(275)] Failed to send GetTerminationStatus message to zygote
                      0|mm  | [25978:1009/112505.812741:ERROR:zygote_communication_linux.cc(275)] Failed to send GetTerminationStatus message to zygote
                      0|mm  | [25978:1009/112505.848727:ERROR:network_service_instance_impl.cc(470)] Network service crashed, restarting service.
                      0|mm  | [25978:1009/112505.880738:ERROR:gpu_process_host.cc(968)] GPU process launch failed: error_code=1002
                      0|mm  | [25978:1009/112505.897587:ERROR:gpu_process_host.cc(968)] GPU process launch failed: error_code=1002
                      0|mm  | [25978:1009/112505.917812:ERROR:gpu_process_host.cc(968)] GPU process launch failed: error_code=1002
                      0|mm  | [25978:1009/112505.942511:ERROR:gpu_process_host.cc(968)] GPU process launch failed: error_code=1002
                      0|mm  | [25978:1009/112505.959337:ERROR:gpu_process_host.cc(968)] GPU process launch failed: error_code=1002
                      And later in the restart process I saw these errors:
                      0|mm  | [09.10.2022 11:25.36.393] [ERROR]
                      0|mm  | (node:26362) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                      0|mm  | (Use `electron --trace-deprecation ...` to show where the warning was created)
                      I did go in and check for the line export ELECTRON_DISABLE_GPU=1 in the startup script mm.sh and it is there. I did have two startup scripts (one that was created before your script was a a thing) and made sure it was there in both as I wasn’t sure which pm2 was using. The original is out in the home folder - I made a backup and then ran your pm2 setup script. While it seemed to reconfigure pm2 to use the script in ~/MagicMirror/installers it still crashes. Figured I would try that in case something was walking over itself.
                      Could this be an Electron version issue?
                        @pattanner92 the buffer thing is a warning, but not our code. nothing we can do
                        the gpu errors are concerning, because u have gpu use turned off.
                        do u know what driver is being used in /boot/config.txt, like this
                        dtoverlay=vc4-fkms-v3d
