    MMM-EnergyMonitor help
    8 Posts 2 Posters 913 Views 2 Watching
      sdetweil @mayfield
      @mayfield open a terminal window and do
      touch ~/MagicMirror/css/custom.css
      that will make the error go away on next load of mm, you can do that with ctrl-r
      ctrl-shift-i to get out of developer mode
        sdetweil @mayfield
        @mayfield how about messages where u start mm
        if npm start
        or of pm2, then
        pm2 logs --lines=50
          mayfield @sdetweil
          @sdetweil Do I run npm start pm2 logs --lines=50?
            sdetweil @mayfield
            @mayfield no
            how do you start MM?
            npm start
            or
            pm2
            if pm2 then
            pm2 logs --lines=50
            in eaither case u may need to redirect the output to a file
            npm start > somefile.txt
            or
            pm2 logs --liness=50 > somefile.txt
              mayfield @sdetweil
              @sdetweil Hear are somefile.txt and my config.js
              > magicmirror@2.21.0 start
              [09.10.2022 09:14.04.452] [LOG]   Starting MagicMirror: v2.21.0
              [09.10.2022 09:14.04.467] [LOG]   Loading config ...
              [09.10.2022 09:14.04.483] [LOG]   Loading module helpers ...
              [09.10.2022 09:14.04.487] [LOG]   No helper found for module: alert.
              [09.10.2022 09:14.04.523] [LOG]   Initializing new module helper ...
              [09.10.2022 09:14.04.526] [LOG]   Module helper loaded: updatenotification
              [09.10.2022 09:14.04.529] [LOG]   No helper found for module: clock.
              [09.10.2022 09:14.04.968] [LOG]   Initializing new module helper ...
              [09.10.2022 09:14.04.977] [LOG]   Module helper loaded: calendar
              [09.10.2022 09:14.05.125] [LOG]   Initializing new module helper ...
              [09.10.2022 09:14.05.149] [LOG]   Module helper loaded: MMM-Fronius2
              [09.10.2022 09:14.05.153] [LOG]   No helper found for module: MMM-EnergyMonitor.
              [09.10.2022 09:14.05.156] [LOG]   No helper found for module: weather.
              [09.10.2022 09:14.05.212] [LOG]   Initializing new module helper ...
              [09.10.2022 09:14.05.213] [LOG]   Module helper loaded: newsfeed
              [09.10.2022 09:14.05.215] [LOG]   All module helpers loaded.
              [09.10.2022 09:14.05.439] [LOG]   Starting server on port 8080 ...
              [09.10.2022 09:14.05.470] [LOG]   Server started ...
              [09.10.2022 09:14.05.472] [LOG]   Connecting socket for: updatenotification
              [09.10.2022 09:14.05.474] [LOG]   Starting module helper: updatenotification
              [09.10.2022 09:14.05.475] [LOG]   Connecting socket for: calendar
              [09.10.2022 09:14.05.477] [LOG]   Starting node helper for: calendar
              [09.10.2022 09:14.05.483] [LOG]   Connecting socket for: MMM-Fronius2
              [09.10.2022 09:14.05.484] [LOG]   Starting module helper: MMM-Fronius2
              [09.10.2022 09:14.05.486] [LOG]   Connecting socket for: newsfeed
              [09.10.2022 09:14.05.488] [LOG]   Starting node helper for: newsfeed
              [09.10.2022 09:14.05.489] [LOG]   Sockets connected & modules started ...
              [09.10.2022 09:14.05.950] [LOG]   Launching application.
              [09.10.2022 09:14.11.582] [LOG]   Create new calendarfetcher for url: https://www.vic.gov.au/sites/default/files/2019-02/Victorian-school-term-dates.ics - Interval: 300000
              [09.10.2022 09:14.11.670] [LOG]   Create new calendarfetcher for url: https://www.vic.gov.au/sites/default/files/2021-09/Victorian-public-holiday-dates.ics - Interval: 300000
              [09.10.2022 09:14.11.687] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
              [09.10.2022 09:14.11.696] [INFO]  Checking git for module: MMM-Fronius2
              [09.10.2022 09:14.11.745] [INFO]  Checking git for module: MMM-EnergyMonitor
              [09.10.2022 09:14.11.796] [INFO]  Checking git for module: default
              [09.10.2022 09:14.12.782] [INFO]  Calendar-Fetcher: Broadcasting 14 events.
              [09.10.2022 09:14.14.376] [INFO]  Newsfeed-Fetcher: Broadcasting 34 items.
              /* MagicMirror² Config Sample
               * By Michael Teeuw https://michaelteeuw.nl
               * MIT Licensed.
               * see https://docs.magicmirror.builders/configuration/introduction.html
               * and https://docs.magicmirror.builders/modules/configuration.html
              let config = {
              	address: "localhost", 	// Address to listen on, can be:
              	port: 8080,
              	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
              	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
              	language: "en",
              	locale: "en-AU",
              	timeFormat: 24,
              	units: "metric",
              			module: "alert",
              			module: "updatenotification",
              			position: "top_bar"
              			module: "clock",
              			position: "top_left"
                                      header: "Holidays",
                                                              symbol: "calendar-check",
                                                              maximumEntries: '4',
                                                              //url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
                                                              url: "https://www.vic.gov.au/sites/default/files/2019-02/Victorian-school-term-dates.ics"
                                                              symbol: "birthday-cake",
                                                              maximumEntries: "10",
                                                              url: "https://www.vic.gov.au/sites/default/files/2021-09/Victorian-public-holiday-dates.ics",
                                      module: 'MMM-Fronius2',
                                      header: "Solar Panels",
                                      hidden: false,
                                      ip: "192.168.2.146",
                                      updateInterval: 3000,
                                      wattConversionOptions: {
                                              enabled: true,
                                              threshold: 1200,
                                              numDecimalDigits: 2,
                                      offlineDetectionOptions: {
                                              numRequests: 5, // Converter is considered offline after this num of failed requests
                                              offlineInterval: 1800000, // 30 Minutes
                                      requestTimeout: 1000,
                                      broadcastSolarPower: true,
                                      broadcastGridPower: true,
                                      broadcastBatteryPower: true,
                                      dummyData: false,
                          		module: 'MMM-EnergyMonitor',
              			disabled: false,
                          		position: 'middle_center',
              			hidden: false,
                      		energyStorage: false,
                      		width: "100px",
                      		height: "100px",
                      		lineWidth: "8px",
                      		resetCycles: 3,
                      		logNotifications: false,
                         			enabled: true,
                          			threshold: 1200,
                      		iconCssClasses: {
                          			home: "fas fa-home",
                          			grid: "fas fa-plug",
                          			energyStorage: "fas fa-battery-half",
                          			localPowerSource: "fas fa-solar-panel",
              			module: "compliments",
              			disabled: true,
              			position: "lower_third"
              			module: "weather",
              				type: "current",
              				locationID: "2166819", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
              				apiKey: "7e845e5fc36ce2a73900ec4152ca884c"
              			module: "weather",
              			header: "Weather Forecast",
              				type: "forecast",
              			module: "newsfeed",
              			position: "bottom_bar",
              				feeds: [
              						title: "New York Times",
              						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
              				showSourceTitle: true,
              				showPublishDate: true,
              				broadcastNewsFeeds: true,
              				broadcastNewsUpdates: true
