    MMM-EnergyMonitor help
    8 Posts 2 Posters 1.2k Views 2 Watching
      mayfield
      Hello everyone
      https://github.com/deg0nz/MMM-EnergyMonitor
      I’m having no luck with this module and was wondering if anyone else has had any? I understand this module calls data from MMM-Fronius2 module which I have working., Below is a picture and you can see the data from the Fronius2 module on the left is working but nothing on the EnergyMonitor module.
      I’m not sure where to begin troubleshooting this I think the problem is in how the two modules communicate any ideas?
      alt text
        sdetweil @mayfield
        @mayfield can you show the config if the two modules, and any messenger in the console output, or in the developers window console ctrl-shift-i on the keyboard, select the console tab and scroll up to see any messages in red
          mayfield @sdetweil
          @sdetweil said in MMM-EnergyMonitor help:
          Here is a photo of the console screen.
          alt text
          S 2 Replies Last reply Reply Quote 1
            sdetweil @mayfield
            @mayfield open a terminal window and do
            touch ~/MagicMirror/css/custom.css
            that will make the error go away on next load of mm, you can do that with ctrl-r
            ctrl-shift-i to get out of developer mode
              sdetweil @mayfield
              @mayfield how about messages where u start mm
              if npm start
              or of pm2, then
              pm2 logs --lines=50
                mayfield @sdetweil
                @sdetweil Do I run npm start pm2 logs --lines=50?
                  sdetweil @mayfield
                  @mayfield no
                  how do you start MM?
                  npm start
                  or
                  pm2
                  if pm2 then
                  pm2 logs --lines=50
                  in eaither case u may need to redirect the output to a file
                  npm start > somefile.txt
                  or
                  pm2 logs --liness=50 > somefile.txt
                    mayfield @sdetweil
                    @sdetweil Hear are somefile.txt and my config.js
                    > magicmirror@2.21.0 start
                    [09.10.2022 09:14.04.452] [LOG]   Starting MagicMirror: v2.21.0
                    [09.10.2022 09:14.04.467] [LOG]   Loading config ...
                    [09.10.2022 09:14.04.483] [LOG]   Loading module helpers ...
                    [09.10.2022 09:14.04.487] [LOG]   No helper found for module: alert.
                    [09.10.2022 09:14.04.523] [LOG]   Initializing new module helper ...
                    [09.10.2022 09:14.04.526] [LOG]   Module helper loaded: updatenotification
                    [09.10.2022 09:14.04.529] [LOG]   No helper found for module: clock.
                    [09.10.2022 09:14.04.968] [LOG]   Initializing new module helper ...
                    [09.10.2022 09:14.04.977] [LOG]   Module helper loaded: calendar
                    [09.10.2022 09:14.05.125] [LOG]   Initializing new module helper ...
                    [09.10.2022 09:14.05.149] [LOG]   Module helper loaded: MMM-Fronius2
                    [09.10.2022 09:14.05.153] [LOG]   No helper found for module: MMM-EnergyMonitor.
                    [09.10.2022 09:14.05.156] [LOG]   No helper found for module: weather.
                    [09.10.2022 09:14.05.212] [LOG]   Initializing new module helper ...
                    [09.10.2022 09:14.05.213] [LOG]   Module helper loaded: newsfeed
                    [09.10.2022 09:14.05.215] [LOG]   All module helpers loaded.
                    [09.10.2022 09:14.05.439] [LOG]   Starting server on port 8080 ...
                    [09.10.2022 09:14.05.470] [LOG]   Server started ...
                    [09.10.2022 09:14.05.472] [LOG]   Connecting socket for: updatenotification
                    [09.10.2022 09:14.05.474] [LOG]   Starting module helper: updatenotification
                    [09.10.2022 09:14.05.475] [LOG]   Connecting socket for: calendar
                    [09.10.2022 09:14.05.477] [LOG]   Starting node helper for: calendar
                    [09.10.2022 09:14.05.483] [LOG]   Connecting socket for: MMM-Fronius2
                    [09.10.2022 09:14.05.484] [LOG]   Starting module helper: MMM-Fronius2
                    [09.10.2022 09:14.05.486] [LOG]   Connecting socket for: newsfeed
                    [09.10.2022 09:14.05.488] [LOG]   Starting node helper for: newsfeed
                    [09.10.2022 09:14.05.489] [LOG]   Sockets connected & modules started ...
                    [09.10.2022 09:14.05.950] [LOG]   Launching application.
                    [09.10.2022 09:14.11.582] [LOG]   Create new calendarfetcher for url: https://www.vic.gov.au/sites/default/files/2019-02/Victorian-school-term-dates.ics - Interval: 300000
                    [09.10.2022 09:14.11.670] [LOG]   Create new calendarfetcher for url: https://www.vic.gov.au/sites/default/files/2021-09/Victorian-public-holiday-dates.ics - Interval: 300000
                    [09.10.2022 09:14.11.687] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                    [09.10.2022 09:14.11.696] [INFO]  Checking git for module: MMM-Fronius2
                    [09.10.2022 09:14.11.745] [INFO]  Checking git for module: MMM-EnergyMonitor
                    [09.10.2022 09:14.11.796] [INFO]  Checking git for module: default
                    [09.10.2022 09:14.12.782] [INFO]  Calendar-Fetcher: Broadcasting 14 events.
                    [09.10.2022 09:14.14.376] [INFO]  Newsfeed-Fetcher: Broadcasting 34 items.
                    /* MagicMirror² Config Sample
                     * By Michael Teeuw https://michaelteeuw.nl
                     * MIT Licensed.
                     * see https://docs.magicmirror.builders/configuration/introduction.html
                     * and https://docs.magicmirror.builders/modules/configuration.html
                    let config = {
                    	address: "localhost", 	// Address to listen on, can be:
                    	port: 8080,
                    	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                    	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                    	language: "en",
                    	locale: "en-AU",
                    	timeFormat: 24,
                    	units: "metric",
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			position: "top_left"
                                            header: "Holidays",
        symbol: "calendar-check",
        maximumEntries: '4',
        //url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
        url: "https://www.vic.gov.au/sites/default/files/2019-02/Victorian-school-term-dates.ics"
        symbol: "birthday-cake",
        maximumEntries: "10",
        url: "https://www.vic.gov.au/sites/default/files/2021-09/Victorian-public-holiday-dates.ics",
                                            module: 'MMM-Fronius2',
                                            header: "Solar Panels",
                                            hidden: false,
                                            ip: "192.168.2.146",
                                            updateInterval: 3000,
                                            wattConversionOptions: {
                                                    enabled: true,
                                                    threshold: 1200,
                                                    numDecimalDigits: 2,
                                            offlineDetectionOptions: {
                                                    numRequests: 5, // Converter is considered offline after this num of failed requests
                                                    offlineInterval: 1800000, // 30 Minutes
                                            requestTimeout: 1000,
                                            broadcastSolarPower: true,
                                            broadcastGridPower: true,
                                            broadcastBatteryPower: true,
                                            dummyData: false,
                                		module: 'MMM-EnergyMonitor',
                    			disabled: false,
                                		position: 'middle_center',
                    			hidden: false,
                            		energyStorage: false,
                            		width: "100px",
                            		height: "100px",
                            		lineWidth: "8px",
                            		resetCycles: 3,
                            		logNotifications: false,
                               			enabled: true,
                                			threshold: 1200,
                            		iconCssClasses: {
                                			home: "fas fa-home",
                                			grid: "fas fa-plug",
                                			energyStorage: "fas fa-battery-half",
                                			localPowerSource: "fas fa-solar-panel",
                    			module: "compliments",
                    			disabled: true,
                    			position: "lower_third"
                    			module: "weather",
                    				type: "current",
                    				locationID: "2166819", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                    				apiKey: "7e845e5fc36ce2a73900ec4152ca884c"
                    			module: "weather",
                    			header: "Weather Forecast",
                    				type: "forecast",
                    			module: "newsfeed",
                    			position: "bottom_bar",
                    				feeds: [
                    						title: "New York Times",
                    						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                    				showSourceTitle: true,
                    				showPublishDate: true,
                    				broadcastNewsFeeds: true,
                    				broadcastNewsUpdates: true
