    Ora.pm
    11 Posts 2 Posters 3.0k Views 2 Watching
      sdetweil @ZeroCool
      @ZeroCool i hear you… lots of learning to get what you want
      • Z Offline
        ZeroCool @sdetweil
        @sdetweil Thanks. I have tried this and got no where. Appreciate the link regardless
        • Z Offline
          ZeroCool @sdetweil
          @sdetweil I have been playing wround with MMM-JsonTable but to no avail. This is where I can download the json api for the app I am trying to add but I am not finding anything that works for this.
            sdetweil @ZeroCool
            @ZeroCool so, I just used the sample from the url you posted for tasks
              "milestone_id": 1234,
              "task_type": 1234,
              "creator": 1234,
              "second_id": 10,
              "title": "Cool task title",
              "description": "Here you can tell something about the task.",
              "last_picture": "ora-projects.s3.amazonaws.com/default-15.svg",
              "last_picture_external_url": "ora-projects.s3.amazonaws.com/default-15.svg",
              "created_at": "2019-07-31T12:42:49.096305Z",
              "updated_at": "2019-07-31T12:42:49.096305Z",
              "deadline": "2019-09-12T15:22:33.106501Z",
              "archived": true,
              "color": "#473a4f",
              "estimated": "16:33:22",
              "time_tracked": "10:12:33",
              "public": "true",
              "state": "1, 2, 3 or 4",
              "cover_width": 10,
              "cover_height": 10,
              "checklist": "1/10",
              "comments": 20,
              "public_comments": 14,
              "likes": 9,
              "attachments": 6,
              "commits": 3,
              "support_tickets": 1,
              "value": 12,
              "points": 10,
              "points_done": 5,
              "sprint_id": 1234,
              "position": 13
            one would hope that you get an array(square brackets around) of tasks (I’ve dupped the one entry, and change the title and description fields, and given it an attribute in the returned response) output from jsonvalidator format
            https://codebeautify.org/jsonvalidator?/jsonvalidate
              "fribble": [
                  "task_type": 1234,
                  "creator": 1234,
                  "second_id": 10,
                  "title": "Cool task title 2",
                  "description": "Here you can tell something about the task. again",
                  "archived": true,
                  "color": "#473a4f",
                  "public": "true",
                  "cover_width": 10,
                  "cover_height": 10,
                  "comments": 20,
                  "likes": 9,
                  "attachments": 6,
                  "commits": 3,
                  "value": 12,
                  "points": 10,
                  "points_done": 5,
                  "sprint_id": 1234,
                  "position": 13
                  "task_type": 1234,
                  "creator": 1234,
                  "second_id": 10,
                  "archived": true,
                  "color": "#473a4f",
                  "public": "true",
                  "cover_width": 10,
                  "cover_height": 10,
                  "comments": 20,
                  "likes": 9,
                  "attachments": 6,
                  "commits": 3,
                  "value": 12,
                  "points": 10,
                  "points_done": 5,
                  "sprint_id": 1234,
                  "position": 13
            so then in JSONTable the
            arrayName
            property would the “fribble” from above
            arrayName:"fribble",
            by default it will show EVERY item in each element of the array… not good for large items
            so, the
            keepColumns
            property will allow you select the data items from each ‘record’ u want
            keepColumns:[ "title","description","sprint_id","archived"],
            you can put nice titles over the columns with the
            descriptiveRow
            property
            its html, in table row/column format
            descriptiveRow: '<tr><td>Title</td><td>Description</td><td>Sprint</td><td>is Archived</td></tr>',
            so the config would be (using the data above, correct as required from the data you get)
                 module: "JsonTable",
                position: ????,
                   url: "https://api.ora.pm/projects/12345/tasks",
            Z 1 Reply Last reply Reply Quote 0
            • Z Offline
              ZeroCool @sdetweil
              @sdetweil Thanks for this. I am trying to process it all.
                sdetweil @ZeroCool
                @ZeroCool I just edited my ‘config’ to add a mostly correct tasks url
                it needs a real projectID (in place of the 12345)
                • Z Offline
                  ZeroCool @sdetweil
                  @sdetweil I will compensate you for your time if you can help me do this. These things are not in my skillset but I have invested a fair amount of money in a TV and MacMini to make this work in my office. Let me know
                    sdetweil @ZeroCool
                    @ZeroCool sent u a chat message
