    MMM-CTA black screen after installation
    4 Posts 2 Posters 969 Views 2 Watching
    • H
      ht3
      I’ve only installed this module, and I’ve configured it how I was supposed to, but whenever I try to start magicmirror I just get a black screen.
      and here is what the config looks like.
      Appreciate any help!
        @ht3 can u show the top of config.js?
        also this mta module is missing a library, request
        see this https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
        but there is another problem before that
        H 1 Reply Last reply
        • H
          ht3 @sdetweil
          @sdetweil sure thing. I’ll post the whole thing.
          c/* MagicMirror² Config Sample
           * By Michael Teeuw https://michaelteeuw.nl
           * MIT Licensed.
           * see https://docs.magicmirror.builders/configuration/introduction.html
           * and https://docs.magicmirror.builders/modules/configuration.html
          let config = {
          	address: "localhost", 	// Address to listen on, can be:
          	port: 8080,
          	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
          	language: "en",
          	locale: "en-US",
          	timeFormat: 24,
          	units: "metric",
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			header: "US Holidays",
          						symbol: "calendar-check",
          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
          			module: "compliments",
          			position: "lower_third"
          			module: "weather",
          				type: "current",
          				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				apiKey: "YOUR_OPENWEATHER_API_KEY"
          			module: "weather",
          			header: "Weather Forecast",
          				type: "forecast",
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "New York Times",
          						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
          				showSourceTitle: true,
          				showPublishDate: true,
          				broadcastNewsFeeds: true,
          				broadcastNewsUpdates: true
          			module: 'MMM-CTA',
          			position: 'bottom_left',
          				updateTime: 60000, // 1 minute, the API does not update much more often so going below this is unnecessary
          				//ctaApiKey: 'you-bus-APIkey',
          				//busStopName: '',  // String value, Name your bus stop
          				//stopId: 561, // Bus station ID: Chicago and Milwaukee example; go to http://www.transitchicago.com/riding_cta/systemguide/default.aspx to find your stop ID
          				//maxResult: 4,  // The maximum number of incoming bussesy you want to display for bus stops
          				ctaApiKeyTrain: 'key',
          				trainStopName: 'Central Park',  //String value, name your train stop
          				trainStationID: 40780, //Train station ID:  Chicago Blue line example; http://www.transitchicago.com/developers/ttdocs/default.aspx#_Toc296199909
          				maxResultTrain: 5, // Max number of incoming trains to disply
          				moduleInstance: 1, // To run multiple instances of this module
            sdetweil @ht3
            @ht3 said in MMM-CTA black screen after installation:
            c/* MagicMirror²
            only need the first line. that nasty little c as the 1st character… please remove that
