New to MM, how do I send a notification to a module?
2 Posts 2 Posters 992 Views 2 Watching
    StormyWaters2021
    I have a MM set up that I am accessing via SSH. I want to use the module MMM-StopwatchTimer, which says it can be controlled via notifications, such as “START_STOPWATCH”.
    I tried reading through the documentation on the wiki, but I don’t understand how/where/what to type to get that notification into that module? Is it possible via SSH? Do I need to be in the root folder, or the MagicMirror folder, or does it matter? When it says “this.sendNotification” do I type that exactly, or do I replace “this” with the name of the module?
    Help!! Thanks in advance!
    S 1 Reply Last reply Dec 10, 2022, 1:03 AM Reply Quote 0
      sdetweil @StormyWaters2021
      @StormyWaters2021 notifications only cone from another module.
      but you are in luck. one of our members just created a tool to send them from a command line tool… see
      https://forum.magicmirror.builders/topic/17252/mmm-commandtonotification-run-scripts-and-send-the-outputs-as-configurable-notifications-peridocally?_=1670633661154
