    Module not showing up
    16 Posts 2 Posters 4.0k Views 2 Watching
      sdetweil @basho429
      @basho429 edit the module node_helper.js and change this
                          if (!error && response.statusCode == 200) {
                              //Good response
                              var resp = body; //needle automagically parses the response as JSON
                              resp.instanceId = payload.instanceId;
                              self.sendSocketNotification("OPENWEATHER_ONE_CALL_FORECAST_DATA", resp);
                          } else {
                              console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " ** ERROR ** " + error);
      to this
                          if (!error){
                              // Good response
                              if(response.statusCode == 200) {
                                  console.log(" needle responding="+JSON.stringify(resp))
                              else {
                                  console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " ** bad status ** " + response.statusCode);
                          } else {
      then restart MagicMirror, and look at the messages again
      at least u will get a good error report
        sdetweil @basho429
        @basho429 on your config…
        please always use the code block marker for config info.
        paste your text
        select it all
        hit the button above the editor that looks like </>
        u can edit the existing post and change it
          basho429 @sdetweil
          I changed the module node_helper.js and restarted MagicMirror. However, I am still not getting any new error message. It’s still the same NULL error. Can you please check below and see if I changed it properly? Thank you.
          /* Magic Mirror
           * Module: MMM-BMW-OW
           * By Mykle1
           * MIT Licensed
          const NodeHelper = require('node_helper');
          const request = require('request');
              start: function() {
                  console.log("Starting node_helper for: " + this.name);
              getWeather: function(url) {
                  request({
                      url: 'https://api.openweathermap.org/data/2.5/onecall?lat=' + this.config.lat + '&lon=' + this.config.lon + '&units=' + this.config.units + '&lang=' + this.config.language + '&appid=' + this.config.api,
                      method: 'GET'
                  }, (error, response, body) => {
                      if (!error){
                                  // Good response
                                  else {
                  if (notification === 'GET_WEATHER') {
                      this.getWeather(payload);
                  if (notification === 'CONFIG') {
                      this.config = payload;
            sdetweil @basho429
            @basho429 that is not the changed new code… that is the old code
              basho429 @sdetweil
              Below is the complete module node_helper,js that came with the module. Can you please send me back what it should contain to get more info about the error? Thank you.
              /* Magic Mirror
               * By Mykle1
               * MIT Licensed
                  start: function() {
                      request({
                          method: 'GET'
                              var result = JSON.parse(body);
                              //	console.log(body); // for checking
                              this.sendSocketNotification('WEATHER_RESULT', result);
                sdetweil @basho429
                @basho429 ok, we are talking different modules now
                that is the MMM-BMW-OW module
                to get its helper back, in that module folder do
                git checkout node_helper.js
                my code goes in the node_helper.js for MMM-OpenWeatherMapForecast module only
                  basho429 @sdetweil
                  Apologies for the mix-up. Noob mistake. I was looking at the wrong node_helper.js. I changed the correct node_helper.js and got an error message that says ** bad status ** 401. What does that mean? Thank you.
                    sdetweil @basho429
                    @basho429 401 is authorization error… so your api_key is not good…
                    we had to make a change in the default module that uses openweathermap
                    try changing this
                    "https://api.openweathermap.org/data/2.5/onecall"
                    to this
                    "https://api.openweathermap.org/data/3.0/onecall"
                      basho429 @sdetweil
                      I am using the same api key for the default weather module that came with MagicMirror (and it works fine). Does that mean I need separate api keys for separate modules? Or I can only use one weather module at a time?
                      I made the change from 2.5 to 3.0 on the node_helper.js.
                      Thank you.
                        sdetweil @basho429
                        @basho429 did the change make a difference?
                        I do not know otherwise
                          basho429 @sdetweil
                          I created a new api key but I am still getting a 401 error.
                          I will remove the module and re-install. Maybe that will work.
                          Any suggestions?
                          Thank you.
                            sdetweil @basho429
                            @basho429 reinstalling the module won’t help
