    MMM-WeatherAlerts
    31 Posts 7 Posters 18.1k Views 9 Watching
      croc_dad72
      Is there a specific lat/lon list to use, I’ve tried several different combinations and locations and I can’t get module to show?
      G 1 Reply Last reply
      • G
        Gjones93 @JohnGalt
        @JohnGalt Thanks for checking out my module.
        With regard to your question of “what constitutes an alert that will trigger the module”: the answer is any alert that is provided by the openWeatherMap one-call API. As far as “what alerts are provided by openWeatherMap”, the details are shared on their website in the section linked here. They list the following reporting agencies for the US:
        • Environmental Protection Agency (EPA), Air Quality Alerts
          Integrated Public Alerrt and Warning System (IPAWS)
        • National Oceanic and Atmospheric Administration (NOAA)
        • National Tsunami Warning Center
        • National Weather Service
        • National Weather Service - Marine Zones
        • U.S. Geological Survey (USGS), Volcano Hazard Program
        I verified the behavior that you described for the lan and lon you provided. Upon further investigation, it looks like the module is performing properly, but there is no alert coming from the OpenWeatherMap API.
        I am sending the OpenWeatherMap team an email with the details of the NWS Blizzard Warning and lack of a corresponding alert data from their API. I will let you know if I hear a reply.
        From the testing I have done previously, it looks like the NWS has different regions that are responsible for sending their own alerts. There may be an outage from the Alaska region, specifically National Weather Service Fairbanks AK.
        Unrelated to this issue, I noticed that you have the module position set to “bottom-bar”. I hadn’t tested that position until just now and the styling is not optimized for that location. I’m going to see about fixing that.
        • G
          Gjones93 @croc_dad72
          @croc_dad72 The module will only be visible if an alert is active for the given lat/lon. Are you expecting an active weather alert for the location you are using? If yes, can you share a lat/lon and I would be happy to investigate further?
          Here is a lat/lon that currently has an active alert and the module appears with the relevant alerts; you can use these as a test:
          lat: "38.93323"
          lon: "-119.98435"
          C 1 Reply Last reply
            croc_dad72 @Gjones93
            @Gjones93 I think the issue is the one call subscription, I thought this worked with the free api or the same api at the weather forecast api.
            • G
              @croc_dad72 If your API key is for version 3.0 of the API, then yes you would need to subscribe to their onecall API to be able to receive alert data. Unfortunate that they changed the onecall model to subscriber based.
              C J 4 Replies Last reply
                @Gjones93 Honestly, im not really sure what I have, I know I signed up for free? I also put in lat/lon for concord ms(42.4604,-71.3489), which is under an active watch and nothing is showing on my mirror? Sorry for the trouble, in relatively new to this, so im sure I did something wrong!
                  JohnGalt @Gjones93
                  @Gjones93: I do have it working now [I think the original issue was bad installation on my part]. FWIW, I also moved it up from the bottom bar to the top bar, and it is displaying the current wind alert at my location just fine. Thanks again.
                    JohnGalt @Gjones93
                    @Gjones93: BTW, when I set alertTimeFormat to absolute [overriding the default ‘relative’] - I get a black screen on the display, and the web page won’t load on the remote machine. I haven’t done any troubleshooting on this yet, but it has the feel of a module using an old library that is no longer supported…
                      @Gjones93 Maybe I don’t understand how to get right api then? I went in and subscribed, created a new api in the api generator, and is still isn’t working? I was able to borrow someone else’s api key for a min and it worked?
                      • G
                        @croc_dad72 I tried that lat and lon and I am seeing the winter weather advisory.
                        Let me ask this: For the other weather modules (e.g. forecast), are you setting an apiVersion parameter in your config file? If yes, to what?
                        Lastly, are you able to share your config layout for the MMM-WeatherAlerts module, minus your apiKey? I’m expecting something like this:
                        			module: "MMM-WeatherAlerts",
                        			header: "Weather Alerts",
                        				lat: "42.4604",
                        				lon: "-71.3489",
                        				colored: true,
                        				alertTimeFormat: "absolute",
                        C 2 Replies Last reply
                        • G
                          Gjones93 @JohnGalt
                          @JohnGalt unable to replicate this issue. I setup my computer as MagicMirror server and then I am able to access the server from my computer’s web-browser and from my raspberry pi acting as a client with both displays showing as expected.
                          Am I misunderstanding your current configuration? Did you happen to set the ‘alertDateFormat’ parameter in your configuration as well?
                          J 1 Reply Last reply
                            @Gjones93 said in MMM-WeatherAlerts:
                            Im just using the default weather from MM, and I have changed any of those parameters at all, just added my api key, and city id.
                            My config:
                            { module: "MMM-WeatherAlerts",
                                  position: "top_right", // top_right
                                    lat: "42.4604",
                                    lon: "-71.3489",
                                    apiKey: "",
                                    colored: true
                              sdetweil @croc_dad72
                              @croc_dad72 please use code block markers for config info
                              paste your text into the message editor,
                              select the text you just pasted
                              and hit the button above the editor that looks like </>
                              that module config is not from MagicMirror
                              that would be
                                      module:'weather'
                                croc_dad72 @sdetweil
                                @sdetweil my apologies, thank you for fixing it!
                                  @Gjones93 Well it seems to be working now, I guess I just needed to give the api time to start working, thanks for all the help!
                                  Reply Quote 2
                                    JohnGalt @Gjones93
                                    @Gjones93 - I am unable to replicate this today, too. It appears to be working as designed today. [There is no active alert at my location, so I changed the lat/lon to the same location in Alaska as before, and a Winter Weather Advisory displays. Both the local and Alaska work on the display and when accessing via a browser at port 8080 on my desktop.] For completeness, no - I did not set or change alertDateFormat from the default in the config.js.
                                    Related but separate query: Does the module take up any space or affect existing modules when it is not actively displaying an alert? I ask because I have several instances of the default weather module stacked in the top_right region, and this module appears to affect their placement.
                                    • G
                                      Gjones93 @JohnGalt
                                      @JohnGalt appreciate the update.
                                      For the module interference while no alerts are active, good eye. This is caused by the default “margin-bottom” that MagicMirror gives to each module. The result is that when no alerts are visible, the module takes up no space, but its margin is still pushing surrounding modules to create the undesired effect that you observed.
                                      I have a quick (slightly-hacky) solution. In your “custom.css” file, add the following:
                                      .MMM-WeatherAlerts {
                                        margin-bottom: 0px;
                                      That should clean up the impact on your default weather modules. The side effect of this is that when there are alerts active, they will be stacked more tightly on-top of one another. I will look and see if I can find a robust way of handling this styling issue so that the spacing is included when the alerts are active and the spacing is “off” when there are no alerts to show. The trick here is that the spacing (margin-bottom) is set by the main app, and not by my module so it may take some work to implement a good solution.
                                      FYI, on my mirror I have the alert module at the bottom of my default weather modules so it avoids this issue all together. Just another option…
                                        JohnGalt @Gjones93
                                        @Gjones93 - Humm, this is interesting. Thanks for the update. While I might just try moving the alert module to the bottom of the stack of weather modules, the core issue I have with it is it appears to also hold on to horizontal real estate when not actively displaying an alert - with the effect of carrying all the modules in that region with it. In my case, I have the weather modules down the right side of the display, narrowed to 82% in custom.css. Sadly, when running your alerts module, I cannot get custom.css to narrow it using the same code, and it also pads out the other modules from the side of the monitor… FWIW, I also tried controlling the alert module width using an absolute number of pixels, but that also had no effect.
                                        The weather css code follows:
                                        .module.weather {
                                          background-color:rgba(255,255,255,0.1);
                                          border-radius:8px;
                                          padding:8px;
                                          text-align: left !important;
                                          width: 82%;
                                          max-width: 82%;
                                          min-width: 82%;
                                          JohnGalt
                                          @Gjones93 - Would there be any reason for this module to stop working? We are currently under an excessive heat warning, but nothing displays… I also tried locating another place under a warning, but it is not triggered by that warning either. Interestingly, when I run 'pm2 logs I don’t see any reference to this module at all. Following is my config:
                                                disabled: false,
                                                position: "top_left", // top_right
                                                // lat: "36.131148", //Las Vegas = 36.131148
                                                // lon: "-115.241867", // Las Vegas = -115.241867
                                                // lat: "62.037360", //Alaska - for testing
                                                // lon: "-163.272301", // Alaska - for testing
                                               lat: "36.753342", // Alfalfa County, Oklahoma - for testing
                                               lon: "-98.355930", // Alfalfa County, Oklahoma - for testing
                                               weatherAlertProvider: "openweathermapalerts",
                                               weatherEndpoint: "/onecall",
                                               type: "alerts",
                                               apiKey: "xxxx",
                                               animationSpeed: 10000, // Default = 1000 (1 second)
                                               alertDateFormat: "llll",
                                               alertDescriptionScrollDelay: 100, // Default = 85, Lower = faster alert description will move
                                               colored: true }, },
                                            JohnGalt
                                            @Gjones93 + @sdetweil – Is there any reason why openweathermap.org would not be returning alerts with the rest of the weather data? I have seen this behavior for some weeks/months now, and wonder whether it might be connected to the new API ver 3.0.
                                            I currently am running both MMM-WeatherAlerts and MMM-OpenWeatherMapForecast. Both used to deliver alerts and neither currently do. I am currently under a wind warning, but no warning displays on either module. I have also found a location in Utah that is currently under a winter storm warning [22 inches of snow falling!], and set the lon/lat there in one MM instance, still with no alert output.
                                            I see no errors in pm2 logs, and do see various other modules showing successful fetching of weather and news - so it looks like this is not a lack of network connection.
                                            Since multiple modules are failing to fetch alerts, it feels like the problem is at the source - openweathermap - or the operation of its API.
                                            Config code for the dev instance follows. Any thoughts?
                                            {module: "MMM-WeatherAlerts",
                                                  disabled: false,
                                                 // header: "Weather Alerts",
                                                 appendLocationNameToHeader: false,
                                                 calendarClass: "calendar",
                                                 tableClass: "small", // small
                                                 // lat: "36.131148",  lon: "-115.241867", //Las Vegas = 36.131148
                                                 lat: "38.549194", lon: "-111.709464", // Fish Lk, Ut - For testing
                                                 // lat: "42.295568", lon: "-83.782281",// Ann Arbor, Mi - for testing
                                                 // lat: "35.152661", lon: "-114.456767", // Lake Mead Rec Area - For testing
                                                 // lat: "36.753342", lon: "-98.355930", // Alfalfa County, Oklahoma - for testing
                                                 // lat: "40.924102", lon: "-115.122002", // Northern Nevada - for testing
                                                 type: "alerts",
                                                 updateInterval: 10800000, // Fetch content every 3 hours
                                                 apiKey: "xxxx", // 19 Sep 2024 Ver 3
                                                 alertTimeFormat: "relative", // absolute
                                                 colored: false }, }, // true
