    MM Default Calendar Filter Full-Day Event Question
    4 Posts 2 Posters 615 Views 2 Watching
      jccjj
      Summary
      Using the default MM Calendar I am trying to filter out or hide the all-day events.
      Example:
      In the MMM-CalendarExt3, I can use an If statement.
      eventFilter: (ev) => {
              if (ev.isFullday) return false
              return true
      For the default cal:
      I have tried to use excludedEvents but I am not sure what to target
      Desired Results:
      • If the Calendar event is full day it is filtered or hidden
        sdetweil @jccjj
        @jccjj the default calendar does not provide a way to filter out events except by text in the event summary
          jccjj @sdetweil
          @sdetweil - Thanks for the confirmation
          I will research other modules… I also use EXT3, which I believe needs the default cal but I have a crazy calendar :)
          Thank you
            sdetweil @jccjj
            @jccjj yes, ext3 uses the info from the default calendar module. it’s a pain to parse the calendar, the author decided to use what we found
