    Default Calendar not updating with new info
    7 Posts 2 Posters 2.4k Views 2 Watching
      dkhorse74 @sdetweil
      @sdetweil said in Default Calendar not updating with new info:
      @dkhorse74 can u pull the ics file after your update and verify the event is there
      curl -sL your_ical_url  >somefile.txt
      then examine somefile.txt for your modified event
      Will do once I get back into town tomorrow. Thanks @sdetweil
        dkhorse74 @dkhorse74
        I created a test event today… I will update the location of this test event tomorrow and run the curl command to see results
          @dkhorse74 said in Default Calendar not updating with new info:
          so the issue is isolated with repeated events.
          If, for example, I enter a repeated event which is to occur every Sunday at the same location and then I edit the location of just one of those repeated events that’s where the location update fails.
          I redirected the URL output (per your suggestion) and I still see the old location in the file. Any ideas what would cause this?
            sdetweil @dkhorse74
            @dkhorse74 no. thats from the Google calendar, nothing on mm side
              sdetweil @dkhorse74
              @dkhorse74 do you see a unique VEVENT
              with recurrence-id set to the base VEVENT datetime?
              this indicates a modified recurrence
