    ChatGpt intergration
    59 Posts 7 Posters 43.1k Views 8 Watching
      sdetweil @SILLEN 0
      @SILLEN-0 the way modules communicate is thru notifications
      sendNotification(someStringvalue, someData)
      it’s a broadcast all modules receive it.
      they examine the someStringvalue and see if it’s important to them and if so they process the someData., if not then they ignore it. there are hundreds of notifications firing all the time.
      so you make a recipe that responds to a voice phrase chatGpt, and the rest is the question
      and u have ga send the notification that your module is looking for.
      you should be able to see the recipe pattern by looking at others that do the same thing.
      once your module recognizes the notification string, then it knows the data is the text of the question.
      you module already has a receiveNotification function, so adding another compare for the notification string is the big work…
        SILLEN 0 @sdetweil
        @sdetweil yea i guess but how in the world would you make it send just the phrase after chatgpt is said. in other words i have no idea how the recipie file should be coded
          sdetweil @SILLEN 0
          @SILLEN-0 you said you understood recipe
            SILLEN 0 @sdetweil
            @sdetweil maybe i formulated it bad. i know how the recipie structure should look like and i can make simple recipies but having the notification only send everything after “chatgpt” that i have no idea how too do. as i said i am a beginner in coding and trying my best
              sdetweil @SILLEN 0
              @SILLEN-0 look at the memo and selfie shoot recipies
              memo gets the rest of the words
              selfie shoot ‘command’ is to send a notification
              when the ‘command’ function is invoked it gets params… ie, the rest of the words
                SILLEN 0 @sdetweil
                @sdetweil ok hello. alot of things have happend in the last week. i have got somthing that should be working but i had too fix abunch of errors in the code. but for the last couple of days i have been stuck on this perticular error in my code:
                0|MagicMirror  | [25.01.2023 21:05.25.175] [LOG]   Error in getResponse:  RangeError: Maximum call stack size exceeded
                0|MagicMirror  |     at isBinary (/home/pi/MagicMirror/node_modules/socket.io-parser/build/cjs/is-binary.js:22:18)
                0|MagicMirror  |     at hasBinary (/home/pi/MagicMirror/node_modules/socket.io-parser/build/cjs/is-binary.js:40:9)
                0|MagicMirror  |     at hasBinary (/home/pi/MagicMirror/node_modules/socket.io-parser/build/cjs/is-binary.js:49:63)
                the internet says that it is probobally a part of the code calling itself but i just cant seem too find anything. it may be super clear what the issue is here but i really cant seem too find the cause of the error. help would be greatly apprecieted. here is my code:
                chatgpt.js:
                Module.register("chatgpt",{
                    defaults: {
                        question: "What is the weather like today?",
                    start: function() {
                        console.log("Starting module: " + this.name);
                        this.question = this.config.question;
                    notificationReceived: function(notification, payload) {
                        if(notification === "ASK_QUESTION") {
                            this.question = payload.question;
                            console.log("Received question: " + this.question);
                            this.sendSocketNotification("ASK_QUESTION", this.question);
                        if(notification === "RESPONSE") {
                            this.answer = payload.answer;
                            console.log("Received answer: " + this.answer);
                            console.log("Calling updateDom");
                            this.updateDom();
                        } else {
                            console.log("Unhandled notification: " + notification);
                            console.log("Payload: " + payload);
                    getDom: function() {
                        var question = document.createElement("div");
                        var answer = document.createElement("div");
                        if (this.answer) {
                            answer.innerHTML = this.answer;
                        } else {
                            answer.innerHTML = "Ask me something";
                        question.innerHTML = this.question;
                        wrapper.appendChild(question);
                        wrapper.appendChild(answer);
                        return wrapper;
                node_helper.js:
                const NodeHelper = require("node_helper");
                const { Configuration, OpenAIApi } = require("openai");
                    start: function() {
                        console.log("Starting node helper for: " + this.name);
                        this.configuration = new Configuration({
                            apiKey: "XXXXXXXXXXXXXXXXXXXXXXXXXX",
                        this.openai = new OpenAIApi(this.configuration);
                    // Send a message to the chatGPT API and receive a response
                    getResponse: function(prompt) {
                        return new Promise(async (resolve, reject) => {
                            try {
                                const response = await this.openai.createCompletion({
                                    model: "text-davinci-003",
                                    prompt: prompt,
                                    temperature: 0.7,
                                console.log("Received response from API: ", response);
                                resolve(response);
                            } catch (error) {
                                console.log("Error in getResponse: ", error);
                                reject(error);
                  // Handle socket notifications
                        if (notification === "ASK_QUESTION") {
                            console.log("Received ASK_QUESTION notification with payload: ", payload);
                            this.getResponse(payload)
                                .then((response) => {
                                    // create a new object and update the answer property
                                    var responsePayload = {answer: response};
                                    console.log("Sending RESPONSE notification with payload: ", responsePayload);
                                    this.sendSocketNotification("RESPONSE", responsePayload);
                                .catch((error) => {
                the api call is being made and everything else is working but as soon as i say “jarvis chatgpt say banana” or any other input i get the error
                  sdetweil @SILLEN 0
                  @SILLEN-0 what is the data format of the response?, text, json, ???
                  you said
                  ‘say banana’
                  did it return a wav file?
                  if u add the MMM-Logging module, then u can see all the logs in one place (output of npm start)
                  socket-io requires a serializable object
                  says error is in getResponse() function,
                  so, did your module get multiple requests concurrently and send them on?
                  I would make the notification string more specific. ‘gpt question’
                  there are hundreds of notifications going on, possible there was another module sending that same string…
                    sdetweil @SILLEN 0
                    @SILLEN-0 also that is the error part of the pm2 logs --lines output
                    when I am developing
                    I don’t use pm2,
                    I just do
                    npm start  >somefile.txt 2>&1
                    in the MagicMirror folder
                    then all the console output is in one file.
                    adding the logging module will reflect all the modulename.js log statements too
                    AND you can debug on the mm UI , ctrl-shift-i,
                    select the sources tab, find your module name.js in the left nav,
                    and you can put stops on lines of code and step thru it
                      SILLEN 0 @sdetweil
                      @sdetweil hey. I’m sorry for not being able too answer but i have other stuff going on and a math test coming up. The text is sent over as a string and the module does recieved the string and gets a response from the API it is after that the issue is caused. I Google the error and people say that there is probably a loop in the code somewhere. I will try with the debug module when i have time. I really want too get this too work.
                        sdetweil @SILLEN 0
                        @SILLEN-0 the data back from the api looks like this
                            status: 200,
                            statusText: 'OK',
                            headers: {
                              date: 'Sun, 29 Jan 2023 23:56:49 GMT',
                              'content-type': 'application/json',
                              'content-length': '343',
                              connection: 'close',
                              'access-control-allow-origin': '*',
                              'cache-control': 'no-cache, must-revalidate',
                              'openai-model': 'text-davinci-003',
                              'openai-organization': 'user-ieyrbalt3azhd9sd82splktg',
                              'openai-processing-ms': '2790',
                              'openai-version': '2020-10-01',
                              'strict-transport-security': 'max-age=15724800; includeSubDomains',
                              'x-request-id': 'd341b29147db89ee20886107e22b41a4'
                              transitional: [Object],
                              adapter: [Function: httpAdapter],
                              transformRequest: [Array],
                              transformResponse: [Array],
                              timeout: 0,
                              xsrfCookieName: 'XSRF-TOKEN',
                              xsrfHeaderName: 'X-XSRF-TOKEN',
                              maxContentLength: -1,
                              maxBodyLength: -1,
                              validateStatus: [Function: validateStatus],
                              headers: [Object],
                              method: 'post',
                              data: '{"model":"text-davinci-003","prompt":"What is the weather like today?","temperature":0.7}',
                              url: 'https://api.openai.com/v1/completions'
                            request: ClientRequest {
                              _events: [Object: null prototype],
                              _eventsCount: 7,
                              _maxListeners: undefined,
                              outputData: [],
                              outputSize: 0,
                              writable: true,
                              destroyed: false,
                              _last: true,
                              chunkedEncoding: false,
                              shouldKeepAlive: false,
                              maxRequestsOnConnectionReached: false,
                              _defaultKeepAlive: true,
                              useChunkedEncodingByDefault: true,
                              sendDate: false,
                              _removedConnection: false,
                              _removedContLen: false,
                              _removedTE: false,
                              _contentLength: null,
                              _hasBody: true,
                              _trailer: '',
                              finished: true,
                              _headerSent: true,
                              _closed: false,
                              socket: [TLSSocket],
                              _header: 'POST /v1/completions HTTP/1.1\r\n' +
                                'Accept: application/json, text/plain, */*\r\n' +
                                'Content-Type: application/json\r\n' +
                                'User-Agent: OpenAI/NodeJS/3.1.0\r\n' +
                                'Authorization: Bearer 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\r\n' +
                                'Content-Length: 89\r\n' +
                                'Host: api.openai.com\r\n' +
                                'Connection: close\r\n' +
                                '\r\n',
                              _keepAliveTimeout: 0,
                              _onPendingData: [Function: nop],
                              agent: [Agent],
                              socketPath: undefined,
                              method: 'POST',
                              maxHeaderSize: undefined,
                              insecureHTTPParser: undefined,
                              path: '/v1/completions',
                              _ended: true,
                              res: [IncomingMessage],
                              aborted: false,
                              timeoutCb: null,
                              upgradeOrConnect: false,
                              parser: null,
                              maxHeadersCount: null,
                              reusedSocket: false,
                              host: 'api.openai.com',
                              protocol: 'https:',
                              _redirectable: [Writable],
                              [Symbol(kCapture)]: false,
                              [Symbol(kNeedDrain)]: false,
                              [Symbol(corked)]: 0,
                              [Symbol(kOutHeaders)]: [Object: null prototype],
                              [Symbol(kUniqueHeaders)]: null
                            data: {
                              object: 'text_completion',
                              created: 1675036608,
                              model: 'text-davinci-003',
                              choices: [Array],
                              usage: [Object]
                          answer: {
                            status: 200,
                            statusText: 'OK',
                            headers: {
                              timeout: 0,
                              maxBodyLength: -1,
                              headers: [Object],
                              method: 'post',
                              _eventsCount: 7,
                              outputData: [],
                              outputSize: 0,
                              writable: true,
                              destroyed: false,
                              _last: true,
                              sendDate: false,
                              _removedTE: false,
                              _hasBody: true,
                              _trailer: '',
                              finished: true,
                              _headerSent: true,
                              _closed: false,
                                '\r\n',
                              agent: [Agent],
                              method: 'POST',
                              _ended: true,
                              aborted: false,
                              timeoutCb: null,
                              parser: null,
                              protocol: 'https:',
                            data: {
                              choices: [Array],
                              usage: [Object]
                        i don’t see the text of the answer
                        P S 3 Replies Last reply Reply Quote 0
                          PraiseU Module Developer @sdetweil
                          @sdetweil Hey any updates on this?
                            @sdetweil Do you have any updates regarding the speech capture process?
                              sdetweil @PraiseU
                              @PraiseU I wasn’t working on any speech capture integration.
                              I outlined the possibilities
                                @sdetweil Oh okay! I found this Module https://github.com/TheStigh/MMM-VoiceCommander. Do you think it can be useful? or does it still have the problem with accuracy?
                                  sdetweil @PraiseU
                                  @PraiseU said in ChatGpt intergration:
                                  yes, it is built on mmm-voice
                                    @sdetweil Can you shed some light on what you mean by this “this is why the MMM-GoogleAssistant provides mechanisms (recipe) to use the captured text for non- google uses” And how can i approach this? Thanks a lot
                                      sdetweil @PraiseU
                                      @PraiseU it’s exactly what it says.
                                      GoogleAssistant collects text from voice.
                                      but many voice commands are not directed at Google itself. ($search, play, turn on/off lights…)
                                      so, if you write a recipe you can direct the text to other purposes
                                        @sdetweil Oh Okay so If I was to say “GPT Explain software engineering” It will get the text and I can forward it to the module it needs to go to? Do you ahave an examples that can help?
                                          sdetweil @PraiseU
                                          @PraiseU i mentioned how to do that before
                                            @sdetweil I think you mis-understood my question? I meant to ask how does the recipes work? Like whats the logic behind it?
                                            • 2 / 3
