    Getting strange error after upgrade with Electron
    12 Posts 2 Posters 2.8k Views 2 Watching
      junkmale
      That didn’t seem to do it. After a pm2 flush, it shows
      /home/pi/.pm2/logs/mm-error.log last 50 lines:
      0|mm | [1176:0208/151743.603505:ERROR:connection.cc(46)] X connection error received.
      0|mm | Gdk-Message: 15:17:43.634: electron: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
      0|mm |
      0|mm | [08.02.2023 15:18.16.665] [WARN] You’re using a full whitelist configuration to allow for all IPs
      0|mm | MESA-LOADER: failed to retrieve device information
      0|mm | MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
      0|mm | failed to load driver: kms_swrast
      0|mm | MESA-LOADER: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
      0|mm | failed to load swrast driver
      0|mm | [998:0208/151919.102171:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
      0|mm | [998:0208/151919.105457:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
        sdetweil @junkmale
        @junkmale did u add that env setting to disable the gpu?
        is this the 64bit os?
        uname -a
          junkmale
          added the GPU setting to mm.sh; this is a Pi 3, ARMv71.
            junkmale @sdetweil
            @sdetweil Not sure if the last response took or not. GPU edit to mm.sh is complete, I did a hard boot afterwards. Response to uname command:
            Linux MagicMirror 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l GNU/Linux
              sdetweil @junkmale
              @junkmale but it still shows active in the pm2 output. did u create a different script for pm2, like in the root of the mm project?
              my install script uses the installers version
                junkmale @sdetweil
                @sdetweil not that I know of.
                pm2 show mm says the script path is /home/pi/mm.sh;
                /home/pi/mm.sh did not have the GPU command in it.
                I did change the one in ~/MagicMirror/installers, but since that doesn’t seem to be the right one,
                I changed the one in /home/pi and pm2 restart mm - and now we have zero errors in the pm2 log.
                One down.
                However…MMM-RAIN-MAP still shows diddly-squat. And it’s still not showing in the right place.
                npm config check comes back without errors. By the way, I thought I posted the question in the MMM-RAIN-MAP forum, but perhaps an error on my part.
                  junkmale @sdetweil
                  @sdetweil Wait! - I think I got it!
                  Thank you!
                    sdetweil @junkmale
                    @junkmale yes, rainmap has a bug on memory I think. the author needs to fix it. open an issue there
