Solved Getting strange error after upgrade with Electron
@junkmale did u add that env setting to disable the gpu?
is this the 64bit os?
uname -a -
added the GPU setting to mm.sh; this is a Pi 3, ARMv71.
@junkmale but it still shows active in the pm2 output. did u create a different script for pm2, like in the root of the mm project?
my install script uses the installers version
@sdetweil not that I know of.
pm2 show mm says the script path is /home/pi/mm.sh;
/home/pi/mm.sh did not have the GPU command in it.
I did change the one in ~/MagicMirror/installers, but since that doesn’t seem to be the right one,
I changed the one in /home/pi and pm2 restart mm - and now we have zero errors in the pm2 log.One down.
However…MMM-RAIN-MAP still shows diddly-squat. And it’s still not showing in the right place.
npm config check comes back without errors. By the way, I thought I posted the question in the MMM-RAIN-MAP forum, but perhaps an error on my part. -
@sdetweil Wait! - I think I got it!
Thank you!
@junkmale yes, rainmap has a bug on memory I think. the author needs to fix it. open an issue there
