    MMM-EveryNews Errors
    5 Posts 2 Posters 965 Views 2 Watching
      SymmetriC
      Installed MMM-EveryNews module, but when I run MagicMirror, the screen turns black and nothing happens. When I quit the process, I get this error:
      Any ideas or recommendations would be greatly appreciated! Thanks in advance!
        sdetweil @SymmetriC
        @SymmetriC see
        https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/1
          SymmetriC
          @sdetweil Thank you for pointing me in the right direction! Reading through that thread, found the fix here: fix for black screen in 2.16 and later
          I did a bunch of other stuff just to start clean, such as deleting the whole ‘node_modules’ folder using:
          rm -r node_modules
          Then ran npm install. Think that helped out to get rid of anything that could have been causing problems. Think I read this in another thread, but I’ll reiterate: Don’t run npm install in your /MagicMirror directory. Don’t know the exact reasoning, but I know that it messes things up (won’t confirm nor deny if I might have done that :grinning_squinting_face: )
          Since I wasn’t getting all the package updates for some reason, I also enabled Universe repositories using
          sudo add-apt-repository universe
          which immediately fixed 3 package errors. After that, I did what @sdetweil recommended here:
          rm -rf node_modules
          rm package-lock.json
          npm install
          then for whatever module was causing problem
          cd ~/MagicMirror/modules/modulename
          do the same last 3 steps as above
          AND THEN
          npm install request --save
          Again, thanks for the help! Hope I can also save someone some headache in the future, which is why I showed all my work here.
            sdetweil @SymmetriC
            @SymmetriC ok, you did WAYYYYYYY too much work.
            the last step was the only thing to do.
              SymmetriC @sdetweil
              @sdetweil HAHAHA! I figured so, but I learned a bunch along the way, so still a success in my book. :call_me_hand:
