    MagicMirror won't run after restart
    11 Posts 2 Posters 4.6k Views 2 Watching
      SymmetriC
      MagicMirror was running great, but after restarting the Pi, now it gets hung up here:
      Any thoughts or suggestions? Thanks in advance!
        sdetweil @SymmetriC
        @SymmetriC where is that image from?
        ssh, a terminal window on the pi?
        when u boot do u see the pi desktop?
          SymmetriC @sdetweil
          @sdetweil image is from the orangePi cmd terminal. When I restarted, everything came up as normal, but when I try to start MagicMirror in the terminal it just hangs up and never starts. Wish it would at least give me some kind of error or something.
            sdetweil @SymmetriC
            @SymmetriC ok, try this
            ctrl-c to stop that
            rm -rf node_modules
            rm package-lock.json
            npm install --omit=dev --no-audit --no-fund
            npm start
              SymmetriC @sdetweil
              @sdetweil Thanks for your quick reply!
              Ran what you said and got this:
              Not sure what it means (researching now), but at least I have an error finally! haha
                sdetweil @SymmetriC
                @SymmetriC typo, should be --no-audit
                  SymmetriC @sdetweil
                  @sdetweil thanks for catching the typo.
                  Ran it again correctly this time; here’s what I have:
                  Still hung up trying to launch MM. I’m lost
                    sdetweil @SymmetriC
                    @SymmetriC well then…
                    instead of npm start, try server only
                    npm run server
                    which takes electron out of the mix
                      @SymmetriC did u try server only?
                      I really have no idea what could be wrong.
                      code reinstall leads to the same problem
                      unless the DISPLAY env variable is wrong
                      in the terminal window do
                      echo $DISPLAY
                      but the other messages should come out before electron is started
                        SymmetriC @sdetweil
                        @sdetweil Appreciate the follow-up. Sorry for my radio silence; replied to the post shortly after your response on Sunday, but guess I wasn’t logged in so it got rejected. Here’s an update:
                        Started MM in npm run server mode, but MMM-EveryNews still wouldn’t load. Great idea though on starting in server to bypass ‘electron’ :thumbs_up: Still dumbfounded why ‘electron’ was having such a hard time.
                        Decided I was done messing with the OrangePi and loaded up a spare RaspberryPi 3 I had laying around. The Pi I was running the MM on was an OrangePi zero2, which is a pretty nice piece of hardware if you are having a hard time finding a good priced RaspberryPi, but I think there may be some driver or OS issues, since it tries to replicate the RaspberryPi OS. :man_shrugging:
                        Loaded up the RaspberryPi with Raspbian, then reloaded all the same MM modules and hit run. Ran like a champ after configuring everything, including https://github.com/mykle1/MMM-EveryNews/issues/5 from @sdetweil.
                        Moral of the story - think either a driver got messed up, an OS file got messed up, or I was messed up. Starting from scratch did the trick though, and it’s up and running.
                        Thanks @sdetweil! I appreciate your help and timely responses!
                          sdetweil @SymmetriC
                          @SymmetriC awesome. thanks for the feedback.
