Unsolved NowPlayingOnSpotify authentication error
Thanks for the reply.
I guess I don’t know what I did wrong and how to correct it. I followed the instructions to the letter.When I type in localhost:8888 to chromium browser, i get the “site can’t be reached”.
Could you explain what you think I am doing wrong and how to fix it?
Please and thank you
@MadeInMaine chromium browser doesn’t sound right. what browser are you using on the system running MagicMirror?
I am not using a browser to run MagicMirror.
I run it through terminal and “npm start” to run it.Not sure if that helps
@MadeInMaine when u do npm start , it starts the MagicMirror app, which displays thru a browser (electron by default)
the black background is electron …
on that screen, press ctrl-shift-i on the keyboard
and a second panel will open, the browser developers window
(just like on Windows, anything built on Firefox or Chrome) -
Looks like electron as it does not look like standard browser.
@MadeInMaine yes. it’s electron (what I said before).
Any advice on how to get the authentication to work?
@MadeInMaine no, clearly something you are doing
Do you know why it would say “site can’t be reached” when doing http://localhost:8888 ?
I tried to go to proxy settings, but couldn’t change anything
@MadeInMaine there are two choices
you are doing that on a browser on a machine different than where MagicMirror is installed
you didn’t start the auth app per the documentation, before you tried to connect to it, from a browser on the same system
