    NowPlayingOnSpotify authentication error
    21 Posts 2 Posters 9.4k Views 2 Watching
      sdetweil @MadeInMaine
      @MadeInMaine this process is authorizing THIS computer to talk to the Spotify system, thru the application you create on the spotify server. has nothing to do with phone or other computer.
      so sounds like you didn’t start the authorization app per the instructions
      M 1 Reply Last reply
        MadeInMaine @sdetweil
        Thanks for the reply.
        I guess I don’t know what I did wrong and how to correct it. I followed the instructions to the letter.
        When I type in localhost:8888 to chromium browser, i get the “site can’t be reached”.
        Could you explain what you think I am doing wrong and how to fix it?
        Please and thank you
          @MadeInMaine chromium browser doesn’t sound right. what browser are you using on the system running MagicMirror?
            I am not using a browser to run MagicMirror.
            I run it through terminal and “npm start” to run it.
            Not sure if that helps
              @MadeInMaine when u do npm start , it starts the MagicMirror app, which displays thru a browser (electron by default)
              the black background is electron …
              on that screen, press ctrl-shift-i on the keyboard
              and a second panel will open, the browser developers window
              (just like on Windows, anything built on Firefox or Chrome)
                Looks like electron as it does not look like standard browser.
                  @MadeInMaine yes. it’s electron (what I said before).
                    Any advice on how to get the authentication to work?
                      @MadeInMaine no, clearly something you are doing
                        Do you know why it would say “site can’t be reached” when doing http://localhost:8888 ?
                        I tried to go to proxy settings, but couldn’t change anything
                          @MadeInMaine there are two choices
                          1. you are doing that on a browser on a machine different than where MagicMirror is installed
                          2. you didn’t start the auth app per the documentation, before you tried to connect to it, from a browser on the same system
                            For #2, I’ll start over from scratch, maybe that will help.
                            For #1, i am using the browser that that opens from the status bar on the RaspberryPi, chromium.
                            Can i use the electron browser? If so, and if I should be using that, where do I find it on the rapsberryPi?
                            Thank you again
                              @MadeInMaine you don’t need to try to use electron.
                              when you start the auth app you should see
                              Listening on 8888
                                I don’t know what “listening on 8888” means.
                                Sorry, could you explain that…
                                  @MadeInMaine the authorization app prints that message to the console.
                                  no ‘meaning’ , does it appear?
                                    No
                                      @MadeInMaine so you did
                                      from the module folder
                                      cd authorization
                                      node app
                                      to start the auth app… right?
