    NowPlayingOnSpotify authentication error
    21 Posts 2 Posters 9.2k Views 2 Watching
      sdetweil @MadeInMaine
      @MadeInMaine yes. it’s electron (what I said before).
        MadeInMaine @sdetweil
        Any advice on how to get the authentication to work?
          @MadeInMaine no, clearly something you are doing
            Do you know why it would say “site can’t be reached” when doing http://localhost:8888 ?
            I tried to go to proxy settings, but couldn’t change anything
              @MadeInMaine there are two choices
              1. you are doing that on a browser on a machine different than where MagicMirror is installed
              2. you didn’t start the auth app per the documentation, before you tried to connect to it, from a browser on the same system
                For #2, I’ll start over from scratch, maybe that will help.
                For #1, i am using the browser that that opens from the status bar on the RaspberryPi, chromium.
                Can i use the electron browser? If so, and if I should be using that, where do I find it on the rapsberryPi?
                Thank you again
                  @MadeInMaine you don’t need to try to use electron.
                  when you start the auth app you should see
                  Listening on 8888
                    I don’t know what “listening on 8888” means.
                    Sorry, could you explain that…
                      @MadeInMaine the authorization app prints that message to the console.
                      no ‘meaning’ , does it appear?
                        No
                          @MadeInMaine so you did
                          from the module folder
                          cd authorization
                          node app
                          to start the auth app… right?
                          per the instructions
