    NowPlayingOnSpotify authentication error
    21 Posts 2 Posters 8.4k Views 2 Watching
      sdetweil @MadeInMaine
      @MadeInMaine chromium browser doesn’t sound right. what browser are you using on the system running MagicMirror?
        MadeInMaine @sdetweil
        I am not using a browser to run MagicMirror.
        I run it through terminal and “npm start” to run it.
        Not sure if that helps
          @MadeInMaine when u do npm start , it starts the MagicMirror app, which displays thru a browser (electron by default)
          the black background is electron …
          on that screen, press ctrl-shift-i on the keyboard
          and a second panel will open, the browser developers window
          (just like on Windows, anything built on Firefox or Chrome)
            Looks like electron as it does not look like standard browser.
              @MadeInMaine yes. it’s electron (what I said before).
                Any advice on how to get the authentication to work?
                  @MadeInMaine no, clearly something you are doing
                    Do you know why it would say “site can’t be reached” when doing http://localhost:8888 ?
                    I tried to go to proxy settings, but couldn’t change anything
                      @MadeInMaine there are two choices
                      1. you are doing that on a browser on a machine different than where MagicMirror is installed
                      2. you didn’t start the auth app per the documentation, before you tried to connect to it, from a browser on the same system
                        For #2, I’ll start over from scratch, maybe that will help.
                        For #1, i am using the browser that that opens from the status bar on the RaspberryPi, chromium.
                        Can i use the electron browser? If so, and if I should be using that, where do I find it on the rapsberryPi?
                        Thank you again
                          @MadeInMaine you don’t need to try to use electron.
                          when you start the auth app you should see
                          Listening on 8888
                            I don’t know what “listening on 8888” means.
                            Sorry, could you explain that…
                              @MadeInMaine the authorization app prints that message to the console.
                              no ‘meaning’ , does it appear?
                                No
                                  @MadeInMaine so you did
                                  from the module folder
                                  cd authorization
                                  node app
                                  to start the auth app… right?
                                  per the instructions
