    MMM-Calendarextplan
    5 Posts 3 Posters 1.3k Views 3 Watching
    • L Offline
      LeonMentor
      Hello Dears,
      I’m looking for a way to change the table width for the event in css.config. Unfortunately, column-width does not change anything. Does anyone have a tip for me?
      Thx
      Hallo meine Lieben,
      ich suche nach einem Weg die Tabellenbreite für das Ereignis in der css.config zu verändern. column-width ändert leider nichts. Hat jemand einen Tipp für mich?
      Danke
        sdetweil @LeonMentor
        @LeonMentor you means custom.css right??
        table is generally constrained by the space it is in…
        each MM ‘position’ has limits
        but the css for table width can be seen here
        https://www.w3schools.com/css/css_table_size.asp
        50% means 50% of the space its in…
        the MM positions
        https://forum.magicmirror.builders/topic/286/regions?_=1678461960892
        • L Offline
          LeonMentor @sdetweil
          @sdetweil Thx for the informations. But I mean the table width in the MMM-CalendarExtPlan Plugin. There I want to change the width of the event column for the calendars.
            @LeonMentor I knew what you meant.
            if. you put the module in the top bar position, the 100% width is screen width,
            if you put the module in top left, the 100% width is 30% of the screen width.
            sometimes modules document the classes used for the table and columns, which u need for your custom.css entries. sometimes not documented, and worse sometimes no easy use classes are provided. then u have to use the developers window to figure it out…
              MMRIZE
              By the way, I’ll provide equivalent CX3 module to alternate this module some day(I hope so…)
