    MMM-OpenAI
    24 Posts 4 Posters 18.1k Views 4 Watching
      sdmydbr9 @sdetweil
      @sdetweil I just meant it as a similar approach, I don’t actually want to implement the whole assistant module.
        sdmydbr9 @MMRIZE
        @MMRIZE I think the Hotword module is not Available anymore and the clap module, might work but it will not look as asthetic as activating with the hot word…
          Rags @MMRIZE
          @MMRIZE said in MMM-OpenAI:
          @Rags
          Speech example: Conjunction with MMM-GoogleTTS, now it can speak.
          https://youtu.be/daWuSfQc5Ns
          postProcessing: (helper, resp) => {
            let choice = resp.response?.choices[0]
            if (choice) helper.sendNotification('TTS_SAY', choice?.message?.content ?? choice?.text)
          I am getting a syntax error in these lines can you please check.
            Rags @Rags
            @MMRIZE
            It’s possible that the error is caused by using optional chaining in a JavaScript version that doesn’t support it.
            I modified the code as below, rewriting the code without using optional chaining.
            postProcessing: function(helper, resp) {
            let choice = resp.response ? resp.response.choices[0] : undefined;
            if (choice) {
            let message = choice.message ? choice.message.content.choice.text : undefined;
            if (message) {
            helper.sendNotification(‘TTS_SAY’, message);
            I am not getting any syntax error now. However, there is some issue with Google TTS (unrelated I think) , as it is sending a notification as TTS_Say_Error. Google TTS API hopefully is configured correctly as no errors are thrown up during starting MM. How should i go about resolving it.
              MMRIZE @Rags
              @Rags
              Give me the front and backend log on error happens
                MMRIZE @Rags
                @Rags
                TTS_SAY notification could have more complex payload like this.
                .sendNotification("TTS_SAY", {
                  content: "Live long and prosper", //text to be spoken
                  //belows are optional
                  type: "text", // "text" or "ssml"
                  voiceName: "en-US-Standard-B",
                  languageCode: "en-US",
                  ssmlGender: "FEMALE",
                  callback: (error)=> {
                    console.log(error) // <= What you need.
                  Rags @Rags
                  @Rags said in MMM-OpenAI:
                  @MMRIZE @MMRIZE
                  Thanks for the update. Yes now it works fine. I am not getting "something is wrong’ messages, but prompts about the token lengths whenever they exceed.
                  Thanks. I hope there will be voice integration soon.
                  So once again some issue has cropped up. The Openai integration with Telegrambot was working fine up to now. However, now the /chatai messages are not getting displayed on the MM whereas they are getting displayed on the Telegrambot app on the phone. The /txtai and /imgai have no issues. Please help in getting it to work again.
                  R M 2 Replies Last reply Reply Quote 0
                    Rags @Rags
                    @MMRIZE @MMRIZE
                    Can the developer please look into the issue described above. Thanks
                      sdetweil @Rags
                      @Rags the developer is on business trip now.
                        MMRIZE @Rags
                        @Rags
                        Give me the whole configuration and log of backend terminal/frontend dev-console. Without details, I cannot guess anything.
                          Rags @sdetweil
                          @sdetweil Oh ok, fine I shall tinker around and see if I have goofed up somewhere and wait for the developer for the rescue. Thanks
                            Rags @MMRIZE
                            @Rags
                            ??backend terminal/frontend dev console…please guide howto ? thanks
