    Black Screens during remote desktop
    5 Posts 2 Posters 1.1k Views 2 Watching
      chris1971
      I try to setup a new mirror. I am working with remote desktop for configuration an testing. When I would like to try the modification via npm start in the console the screen is getting black - the screen on the mirror is working fine.
      Any ideas?
        sdetweil @chris1971
        @chris1971 how are you doing remote desktop?
        electron depends on x-windows
        echo $DISPLAY
        in your remote terminal window
        I would make it accessible from the remote system
        address:'0.0.0.0',
        ipWhitelist:[],
        in config.js
        then u can start it over ssh
        and access fro the system u are using for remote
          chris1971
          I use the remote desktop from Win 10. With the older system it works well.
            chris1971
            with npm start I see following and then a black screen:
            Pi@raspberrypi:~/MagicMirror $ npm start
            magicmirror@2.22.0 start
            [30.03.2023 14:57.53.042] [LOG] Starting MagicMirror: v2.22.0
            [30.03.2023 14:57.53.055] [LOG] Loading config …
            [30.03.2023 14:57.53.073] [LOG] Loading module helpers …
            [30.03.2023 14:57.53.077] [LOG] No helper found for module: alert.
            [30.03.2023 14:57.53.124] [LOG] Initializing new module helper …
            [30.03.2023 14:57.53.126] [LOG] Module helper loaded: updatenotification
            [30.03.2023 14:57.53.128] [LOG] No helper found for module: clock.
            [30.03.2023 14:57.53.792] [LOG] Initializing new module helper …
            [30.03.2023 14:57.53.794] [LOG] Module helper loaded: calendar
            [30.03.2023 14:57.53.984] [LOG] Initializing new module helper …
            [30.03.2023 14:57.53.987] [LOG] Module helper loaded: MMM-OpenWeatherForecast
            [30.03.2023 14:57.53.989] [LOG] No helper found for module: MMM-TextClock.
            [30.03.2023 14:57.59.058] [LOG] Initializing new module helper …
            [30.03.2023 14:57.59.060] [LOG] Module helper loaded: newsfeed
            [30.03.2023 14:57.59.063] [LOG] No helper found for module: MMM-Globe.
            [30.03.2023 14:57.59.078] [LOG] Initializing new module helper …
            [30.03.2023 14:57.59.081] [LOG] Module helper loaded: MMM-GoogleMapsTraffic
            [30.03.2023 14:57.59.083] [LOG] All module helpers loaded.
            [30.03.2023 14:57.59.481] [LOG] Starting server on port 8080 …
            [30.03.2023 14:57.59.496] [WARN] You’re using a full whitelist configuration to allow for all IPs
            [30.03.2023 14:57.59.533] [ERROR] Whoops! There was an uncaught exception…
            [30.03.2023 14:57.59.553] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
            at Server.setupListenHandle [as _listen2] (node:net:1432:16)
            at listenInCluster (node:net:1480:12)
            at doListen (node:net:1629:7)
            at process.processTicksAndRejections (node:internal/process/task_queues:84:21) {
            code: ‘EADDRINUSE’,
            errno: -98,
            syscall: ‘listen’,
            address: ‘0.0.0.0’,
            port: 8080
            [30.03.2023 14:57.59.554] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [30.03.2023 14:57.59.557] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            [30.03.2023 14:58.00.341] [LOG] Launching application.
            MESA-LOADER: failed to retrieve device information
            …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2218:0330/145802.358160:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
            …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2218:0330/145803.485870:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
            …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2218:0330/145804.578316:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
            [30.03.2023 14:58.22.117] [LOG] Shutting down server…
            [30.03.2023 14:58.22.129] [LOG] Stopping module helper: updatenotification
            [30.03.2023 14:58.22.132] [LOG] Stopping module helper: calendar
            [30.03.2023 14:58.22.133] [LOG] Stopping module helper: MMM-OpenWeatherForecast
            [30.03.2023 14:58.22.135] [LOG] Stopping module helper: newsfeed
            [30.03.2023 14:58.22.136] [LOG] Stopping module helper: MMM-GoogleMapsTraffic
              sdetweil @chris1971
              @chris1971 said in Black Screens during remote desktop:
              u have another instance of MagicMirror already running
