    Standard module Calendar hangs on events
    30 Posts 2 Posters 12.2k Views 2 Watching
    • L Offline
      Laz
      I use the display of my two GMail calendars. One calendar (pink) is displayed normally. The second calendar (blue) hangs very often on old events. The event display is not updated. The update delay varies from several hours to several days.
      Here’s an example:
      Today is Thursday. The blue calendar display settled on Tuesday’s event. After reloading, MM2 events are displayed correctly.
      Tomorrow Friday’s event is at 6 a.m.
      The settings for updating calendars are the same.
        sdetweil @Laz
        @Laz can you show the output of npm start, if using pm2 to launch mm, then the pm2 logs command can be used to display the info
        there should be a line for processing the calendar each refresh cycle
        L 2 Replies Last reply Reply Quote 0
        • L Offline
          Laz @sdetweil
          @sdetweil My mirror starts automatically when the raspberry is turned on. If you write in more detail what needs to be done, I will try to follow your advice.
            sdetweil @Laz
            @Laz what makes it autostart?
            pm2 or did u create a sustem service?
            if using pm2
            then
            pm2 logs --lines=100
            might work
            otherwise, probably better to do it manually
            stop mm however you would do it
            ctrl-alt-t to open a terminal window
            npm start >somefile.txt 2>&1
            wait til you think mm should have refreshed the calendar
            press ctrl-q on the mm screen
            examine the contents of somefile.txt
            • L Offline
              Laz @sdetweil
              @sdetweil To update the calendar after hanging, I used just a raspberry reboot. Then my friend helped me make a script to reboot only the mirror software itself.
              And I connected the button to the GPIO raspberry.
              The script is like this -
                sdetweil @Laz
                @Laz so you are using pm2
                • L Offline
                  Laz @sdetweil
                  @sdetweil I set it according to this instruction -
                    sdetweil @Laz
                    @Laz yes, that is my set of scripts…
                    anyhow, pm2’s job is to keep MM (or any other app it manages) running…
                    but it also collects the output from those apps…
                    SO you can use the pm2 command to print out the content it has already saved
                    pm2 --help
                    shows you all the things the command can do .
                    pm2 logs
                    will dump out the info saved
                    the --lines=nn parameter will control how many lines of output to display… the default is just 15… so you may have to increase the number to get more of the output
                    pm2 logs --lines=50 or --lines=100
                    • L Offline
                      Laz @sdetweil
                      @sdetweil Thanks a lot!!!
                      Not everything is clear (Google translator…;))))))))))))))))
                      But I will try today or over the weekend to do everything you wrote and show you the results.
                      • L Offline
                        Laz @sdetweil
                        @sdetweil But I am afraid that the log file may not show an error at a particular moment. Because the hanging events of the blue calendar occur chaotically, not every day…
                        The pink calendar barely freezes in event updates.
                        I changed the arrangement of these calendars (one above the other), but it didn’t help for the blue calendar.
                          sdetweil @Laz
                          @Laz the info, if any, will be in the log
                          you can also see the files holding the log info
                          in the ~/.pm2/logs folder (note the . in front of pm2 here)
                          • L Offline
                            Laz @sdetweil
                            @sdetweil Good afternoon!
                            I did not succeed in doing everything on your advice.
                            But I noticed that the blue calendar had not been updated for several days. And I looked at the log file.
                            It shows that until April 2, two calendars are being updated to 20.56.41. And after 21.01.28, only one calendar began to be updated. And so it was until I overloaded the mirror today.
                            I attach screenshots from the log file.
                              sdetweil @Laz
                              @Laz thanks. that’s the good info. how about the error log? I’m pretty sure there was a timeout error, and once errored, it never recovers.
                              but you should see the timeout error reported on the error log
                              • L Offline
                                Laz @sdetweil
                                Good afternoon!
                                I couldn’t find any calendar related errors.
                                I can’t insert a txt file here. Changing the extension to a picture also does not go away.
                                  sdetweil @Laz
                                  @Laz pic post is the image 3rd from the right on the ioc list above the reply editor
                                  u can paste the text
                                  please use code blocks around
                                  paste
                                  select all the text you just pasted
                                  press the </> button
                                  • L Offline
                                    Laz @sdetweil
                                    @sdetweil I wanted to insert the file. I copied a large piece from the error file into a separate file. It turned out 311 KB.
                                    If you insert this here by copying, then there will be a lot.
                                      sdetweil @Laz
                                      @Laz yeh. forum is a pain some times…
                                      email to me, same userid at gmail
                                      • L Offline
                                        Laz @sdetweil
                                        @sdetweil Yes, OK )
                                          sdetweil @Laz
                                          @Laz got it…
                                          there is the error
                                          [04.04.2023 20:12.18.185] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/.....
                                          internal server error
                                          something happened at google…
                                          and more importantly
                                          [04.04.2023 20:06.53.607] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/....
                                          failed, reason: getaddrinfo EAI_AGAIN calendar.google.com
                                              at ClientRequest.<anonymous> (/home/vova/MagicMirror/node_modules/node-fetch/lib/index.js:1491:11)
                                              at ClientRequest.emit (node:events:513:28)
                                              at TLSSocket.socketErrorListener (node:_http_client:481:9)
                                              at TLSSocket.emit (node:events:513:28)
                                              at emitErrorNT (node:internal/streams/destroy:157:8)
                                              at emitErrorCloseNT (node:internal/streams/destroy:122:3)
                                              at process.processTicksAndRejections (node:internal/process/task_queues:83:21) {
                                            type: 'system',
                                            errno: 'EAI_AGAIN',
                                            code: 'EAI_AGAIN'
                                          we can’t find a path to the server for this…
                                          all outside the pi… so no idea we can’t fix it…
                                          but we keep trying (so that is good)
                                          do you run a pihole ad blocker system? seen this a lot when pihole has a problem
                                          • L Offline
                                            Laz @sdetweil
                                            @sdetweil Yes, I see mistakes now… (
                                            They last more than an hour in the records and then apparently the requests stop.
                                            There is no ad blocker on raspberries. There is just a standard image and then a mirror is installed with a minimum of additional modules.
                                            I noticed in the errors that there is an error of my two calendars. Perhaps at some point really Google becomes unavailable…
                                            Of course, I don’t turn to the calendar so often on my phone and computer.
                                            But today, before loading the mirror, I noticed that the blue calendar has not been updated since April 4. Just the errors are dated April 4th. It turns out that when there are many errors, the module stops accessing the calendar? After all, it cannot be that Google was not available for so many days…
