    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 713.7k Views 57 Watching
      chris1971 @sdetweil
      Short summary: I installed MM new with your script - I agreed to the installation of pm2 and disable screensaver. To get a connection to my WIN 10 via remote desktop computer I need to install sudo apt-get install xrdp. Without this installation I’m not able to start the remote desktop connetcion - Only via putty.
      After the installation I am not able to run npm start without getting a black screen. I have to pm2 stop all - then npm start again and I see the MM screen on my computer to update the modules, config, etc.
      This is what we have seen before:
      [31.03.2023 14:13.31.869] [LOG] Starting server on port 8080 …
      [31.03.2023 14:13.31.892] [WARN] You’re using a full whitelist configuration to allow for all IPs
      [31.03.2023 14:13.31.940] [ERROR] Whoops! There was an uncaught exception…
      [31.03.2023 14:13.31.961] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
      at Server.setupListenHandle [as _listen2] (node:net:1432:16)
      at listenInCluster (node:net:1480:12)
      at doListen (node:net:1629:7)
      at process.processTicksAndRejections (node:internal/process/task_queues:84:21) {
      code: ‘EADDRINUSE’,
      errno: -98,
      syscall: ‘listen’,
      address: ‘0.0.0.0’,
      port: 8080
      With this error MM is running on the Mirror screen without problems.
      When I install MMM-GoogleMapsTraffic I get following message:
      npm ERR! code ERESOLVE
      npm ERR! ERESOLVE could not resolve
      npm ERR!
      npm ERR! While resolving: MMM-GoogleMapsTraffic@1.0.0
      npm ERR! Found: stylelint@14.16.1
      npm ERR! node_modules/stylelint
      npm ERR! peer stylelint@“14.x” from grunt-stylelint@0.18.0
      npm ERR! node_modules/grunt-stylelint
      npm ERR! dev grunt-stylelint@“latest” from the root project
      npm ERR!
      npm ERR! Could not resolve dependency:
      npm ERR! dev stylelint-config-standard@“latest” from the root project
      npm ERR!
      npm ERR! Conflicting peer dependency: stylelint@15.4.0
      npm ERR! peer stylelint@“^15.4.0” from stylelint-config-standard@32.0.0
      npm ERR! node_modules/stylelint-config-standard
      npm ERR!
      npm ERR! Fix the upstream dependency conflict, or retry
      npm ERR! this command with --force, or --legacy-peer-deps
      npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
      npm ERR!
      npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report.
      npm ERR! /home/pi/.npm/_logs/2023-04-01T11_07_55_012Z-debug-0.log
      After installation of MMM-GoogleMapsTraffic the Openweather is not loading anymore.
        sdetweil @chris1971
        @chris1971 we have two different problems going on.
        1. when u start MagicMirror, it will display on the monitor attached to the system. NOT any remote console.
          it IS a mirror on the wall after all
        IF you want to show the mirror screen on a remote system, phone, laptop, tablet, desktop
        then you use a browser on that other device to show the mm screen from it’s server on the mirror system.
        you do not start another running copy of MagicMirror . you do not need rdp to do this.
        just a browser.
        IF you want to display MagicMirror over your rdp session, then you would open a browser thru the rdp session and use the url
        http://localhost:8080
        as rdp makes it like you are at the local desktop
        I’ll look at the Googlemapstraffic problem
          chris1971 @sdetweil
          @sdetweil many thanks - but I have to install/ modify the Mirror from my computer. That’s the reason why I would like to connect via WIFI and get easy access to the modules/ config, etc.
          With Putty I only have access to the terminal - not to the PI Explorer…
          Your recommendation is not to install sudo apt-get install xrdp - it seems that this install mekes the trouble with 2 systems…
            sdetweil @chris1971
            @chris1971 yes, rdp is fine to access the console.
            but from the remote system u just use a browser to see the mm contents
            same as if you used putty to edit the config.js
            try it. that is the whole point of pm2, start the mirror/web server without user intervention
            as u have removed pm2, use putty to logon and npm start. , then disconnect putty
            now use your browser on windows to access the mm web server BEFORE STARTING rdp, using the same IP address as you used for putty
            and port 8080 (the port number in mm config.js)
            if u make a change and restart mm. then hit refresh on the browser page
              chris1971 @sdetweil
              @sdetweil Thanks for your support - a solution for the maps issue would be really nice!!!
              The 1st topic with the remote desktop is my minor challenge
                sdetweil @chris1971
                @chris1971 so looking at MMM-GoogleMapsTraffic , it uses very old stuff (5 years) in its dev dependencies section of package.json
                sadly there is no way to get rid of the error messages without a tiny change
                when u install a module using npm you can ‘omit’ installing the development stuff… BUT, it STILL goes thru all the WORK to check them out (I don’t know why this is stupid)
                anyhow, the ONLY fix is to trick the installer to not FIND any dev dependencies…
                edit package.json
                and change this
                "devDependencies": {
                to this
                "devDependencies1": {
                notice I added the ‘1’ at the end… when npm install runs it will look for “devDependencies”
                and not find it… and skip all the junk (You are not going to be developing on the module anyhow…so no loss and the stuff eliminated is formatting tools anyhow)
                now, that said,
                I installed the module
                copied the default config entry from the readme
                fixed the text typo (missing trailing comma)
                added my apikey from google dev console and
                worked like a champ…
                i did this on two separate systems
                my linux desktop
                and a pi4 w 7in screen
                  sdetweil @chris1971
                  @chris1971 you can also use Winscp or bitvise ssh clients
                  these give you an ssh terminal AND a file browser over the PI files…just click and double click,
                  I use notepad++ on my windows system to edit the config and css files.
                  and the ssh terminal to install mm and modules (where to run commands)
                  and start/restart via pm2 or npm start
                    chris1971 @sdetweil
                    @sdetweil Thanks for this outstanding support!!!
                    I learned o lot - I have installed the MM some years ago and was a little bit concerned if I can do this again…
                    Now the best: The MM is running with Openweather and Goggle Maps - I tried several times install/ deinstall and found your modified script for Maps - maybe this was a solution at the end. I still see some errors in the strting script - but MM is running now with the weather module after shutdown the Darksky service - this was the only reason for me to change the system again…
                    Thanks again!!!
                      sdetweil @chris1971
                      @chris1971 glad you got it running
                      • E
                        Egnos
                        Hello there!
                        Unfortunatly It’s arrived the moment: “… on March 31st, 2023 the Dark Sky API will no longer be available.”, as recalled by the Dark Sky Team in this post: Infos from the Dark Sky Team
                        In fact today morning MMM-DarkSkyForecast stopped working!
                        I tried to install its replacement MMM-OpenWeatherForecast, but it didn’t work!
                        On terminal i hve this error:
                        [MMM-OpenWeatherForecast] 2-Apr-23 17:23 ** ERROR ** Error: Request failed with status code 401
                        I have already try to regen the API key on OpenWeatherMap site but the problem persist.
                        I’m using MagicMirror: v2.22.0
                        For now i’m using the simple configuration:
                            module: "MMM-OpenWeatherForecast",
                            header: "Forecast",
                              apikey: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", //only string here
                              latitude: 45.072870,            //number works here
                              longitude: 7.558791          //so does a string
                        Has anyone had this problem before?
                        Can you help me?
                        Thanks.
                          sdetweil @Egnos
                          @Egnos see https://github.com/jclarke0000/MMM-OpenWeatherForecast/issues/23
                          new openweather api version is 3.0, code is hard coded to 2.5
                          • E
                            Egnos @sdetweil
                            Hi @sdetweil thanks for answering me!
                            I had read this post but I didn’t understand what I have to do.
                            I have to update the node_helper.js version 2.5 to 3.0?
                            Can you help me?
                            Thanks.
                              sdetweil @Egnos
                              @Egnos yes,
                              just edit the file and change 2.5 to 3.0
                              • E
                                Egnos @sdetweil
                                @sdetweil said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                edit the file an
                                In the file “node_helper.js” I have modify:
                                this https://api.openweathermap.org/data/2.5/onecall?
                                with this https://api.openweathermap.org/data/3.0/onecall?
                                but I have the same error:
                                [02.04.2023 17:58.05.910] [LOG]   [MMM-OpenWeatherForecast] 2-Apr-23 17:58 ** ERROR ** Error: Request failed with status code 401
                                Where am I doing wrong?
                                  sdetweil @Egnos
                                  @Egnos i’ve seen a number of these…
                                  something to do with registering correctly with version 3 onecall
                                  someone else said
                                  I used the API keys from the website as the one sent in my email did not work.
                                  • E
                                    Egnos @sdetweil
                                    @sdetweil I’ve already gone to the OpenWeatherMap site, I’ve regenerated a new API key but still the error…
                                      sdetweil @Egnos
                                      @Egnos sorry, that part I don’t know.
                                      I have ow keys for both 2.5 and 3.0, but its been so long, I don’t remember what I did , altho it was only website
                                      • E
                                        Egnos @sdetweil
                                        @sdetweil thanks.
                                        I’m trying to create a new user in the OpenWeatherMap site to have a new API.
                                        In the meantime, if anyone knows how to help me it would be appreciated!:grinning_face_with_sweat:
                                          sdetweil @Egnos
                                          @Egnos i just installed the module and used all my api keys without any problem … I did NOT edit the node_helper…
                                          this is the signup screen I see for v3… need credit card
                                          S E 2 Replies Last reply Reply Quote 0
                                            I signed up for the 3.0 api, they updated my default api key
                                            I changed the code to use 3.0 instead of 2.5
                                            and it worked
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 12 / 13
