    cannot find module
    10 Posts 2 Posters 2.1k Views 2 Watching
      sdetweil @theaddies
      @theaddies what happened right before the error?
      did u upgrade node or npm?
      did you have a power failure?
      • T Offline
        theaddies @sdetweil
        @sdetweil My girfriends daughter pulls the plug on it. So yea, a power failure.
          sdetweil @theaddies
          @theaddies ouch…
          ‘maybe’ this will work, but most of the time I have to replace the sd card
          try
          sudo npm uninstall pm2 -g
          I would reboot here
          then use my script to add it back
          see https://github.com/sdetweil/MagicMirror_scripts
          the fixuppm2 command at the bottom of the page
          even if it works, I would plan to get off that sd card asap
          use my backup/restore scripts to backup the MM info
          https://github.com/sdetweil/MagicMirror-backup-restore
          I am testing a new release,
          select the withfiles dropdown before copy/pasting the backup command
          • T Offline
            theaddies
            Does duplicating the card duplicate the flaw or is the copy good? Or is there a way I can make a copy of the important parts of the OS without duplicating the card?
              sdetweil @theaddies
              @theaddies copying the card copies the troubles
              only way is to start over.
              use my backup script to save your mm config and modules list for reinstall on restore
              use my install script to I shall mm after a new SD card is made and booted
              then run restore
              it’s the fastest way, least amount of work
              • T Offline
                theaddies @sdetweil
                @sdetweil Thanks for the reply. I started over. I just made a posts where I ran your script and can’t get it to work. I don’t know how I ever got this thing working in the first place. I have 3 of them running and now I can’t anything to go. My other post is awaiting approval.
                S 3 Replies Last reply Reply Quote 0
                  sdetweil @theaddies
                  @theaddies I don’t see any pending posts
                    sdetweil @theaddies
                    @theaddies script is copy paste the line from GitHub to terminal window, and hit enter
                    show me the ~/install.log
                      sdetweil @theaddies
                      @theaddies which script? install or backup?
