    Standard module Calendar hangs on events
    30 Posts 2 Posters 12.9k Views 2 Watching
      sdetweil @Laz
      @Laz yeh. forum is a pain some times…
      email to me, same userid at gmail
      • L
        Laz @sdetweil
        @sdetweil Yes, OK )
          sdetweil @Laz
          @Laz got it…
          there is the error
          [04.04.2023 20:12.18.185] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/.....
          internal server error
          something happened at google…
          and more importantly
          [04.04.2023 20:06.53.607] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/....
          failed, reason: getaddrinfo EAI_AGAIN calendar.google.com
              at ClientRequest.<anonymous> (/home/vova/MagicMirror/node_modules/node-fetch/lib/index.js:1491:11)
              at ClientRequest.emit (node:events:513:28)
              at TLSSocket.socketErrorListener (node:_http_client:481:9)
              at TLSSocket.emit (node:events:513:28)
              at emitErrorNT (node:internal/streams/destroy:157:8)
              at emitErrorCloseNT (node:internal/streams/destroy:122:3)
              at process.processTicksAndRejections (node:internal/process/task_queues:83:21) {
            type: 'system',
            errno: 'EAI_AGAIN',
            code: 'EAI_AGAIN'
          we can’t find a path to the server for this…
          all outside the pi… so no idea we can’t fix it…
          but we keep trying (so that is good)
          do you run a pihole ad blocker system? seen this a lot when pihole has a problem
          • L
            Laz @sdetweil
            @sdetweil Yes, I see mistakes now… (
            They last more than an hour in the records and then apparently the requests stop.
            There is no ad blocker on raspberries. There is just a standard image and then a mirror is installed with a minimum of additional modules.
            I noticed in the errors that there is an error of my two calendars. Perhaps at some point really Google becomes unavailable…
            Of course, I don’t turn to the calendar so often on my phone and computer.
            But today, before loading the mirror, I noticed that the blue calendar has not been updated since April 4. Just the errors are dated April 4th. It turns out that when there are many errors, the module stops accessing the calendar? After all, it cannot be that Google was not available for so many days…
              sdetweil @Laz
              @Laz the EAI_AGAIN error is a networking error…
              the library we use does the work , nothing in our code…
              the code needs to get the IP address of the server to connect
              it looks up the name to get the address
              this failed… name not found
              thats all we got… “we can’t look this up now, please try again”
              no idea where in the network from the pi outward what error caused the failure
              L 5 Replies Last reply Reply Quote 0
              • L
                Laz @sdetweil
                @sdetweil I will try to make ping permanent to these addresses (if Google allows ping) or contact the Internet provider.
                • L
                  Laz @sdetweil
                  @sdetweil Good afternoon
                  Here is another very strange situation. Now I see that there is no calendar update. View the error log file, but there are no errors. But the date of the error file is April 8th! Today is April 9th.
                  I’ll give you screenshots and try to overload the mirror.
                  [07.04.2023 10:54.57.922] [ERROR] Newsfeed Error. Could not fetch newsfeed:  http://tyumen-news.net/rss/news Error: Bad Gateway
                      at NodeHelper.checkFetchStatus (/home/vova/MagicMirror/js/node_helper.js:120:9)
                      at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
                  [07.04.2023 14:12.12.283] [ERROR] Newsfeed Error. Could not fetch newsfeed:  https://www.ixbt.com/export/utf8/hardnews.rss Error: Bad Gateway
                  [08.04.2023 05:09.10.408] [ERROR] Newsfeed Error. Could not fetch newsfeed:  https://www.ixbt.com/export/utf8/hardnews.rss Error: Gateway Time-out
                  [08.04.2023 05:14.10.782] [ERROR] Newsfeed Error. Could not fetch newsfeed:  https://www.ixbt.com/export/utf8/hardnews.rss Error: Bad Gateway
                  /home/vova/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                  MESA-LOADER: failed to retrieve device information
                  MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: невозможно открыть разделяемый объектный файл: Отказано в доступе (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                  failed to load driver: kms_swrast
                  MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: невозможно открыть разделяемый объектный файл: Отказано в доступе (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                  failed to load swrast driver
                  [12318:0408/113452.405608:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
                  X connection to :0 broken (explicit kill or server shutdown).
                  It can be seen that on the 8th at 18-00 the second calendar stopped being polled.
                  And at 21-15, the first calendar stopped being interviewed.
                  And there is still no poll.
                  I’m pinging Google right now, ping is great…
                  • L
                    Laz @sdetweil
                    @sdetweil Before rebooting.
                    • L
                      Laz @sdetweil
                      @sdetweil After the reboot. Both calendars were immediately updated.
                      And the error log file was immediately updated!
                      But I don’t see any network-related calendar errors in it… (
                      [1374:0408/120432.325630:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
                      [1374:0408/120432.326975:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
                      [1374:0408/120435.597191:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
                      [6024:0409/124326.890535:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
                      • L
                        Laz @sdetweil
                        @sdetweil Perhaps the error is not related to the availability of Google servers?
                          sdetweil @Laz
                          @Laz the 1st error
                          is Google’s
                          the EAI_AGAIN
                          is not Google’s,
                          your request never made it there as the underlying code couldn’t get the IP address to use.
                          this is a network problem, somewhere
                          • L
                            Laz @sdetweil
                            @sdetweil I sent some messages today. But only the latter got here. There are a little oddities there. Have you read them?))
                            Today, too, calendars have hung, but I have not seen any network errors.
                              sdetweil @Laz
                              @Laz no messages pending
                              I see the links in the posts below but not in the pending list. weird… sorry for the delay
                              these errors are outside of MagicMirror control.some may be recoverable, some may not. we don’t control the network stack
                              • L
                                Laz @sdetweil
                                @sdetweil After tomorrow I will try to repeat briefly…))
