    Electron error: Cannot find module 'envsub'
    10 Posts 4 Posters 3.6k Views 4 Watching
      asd @sdetweil
      @sdetweil thanks for your help.
      The MagicMirror was running well on git commit f14e956 from Feb, 7th 2023.
      When I upgraded via git pull within the ~/MagicMirror folder, the miror would not start anymore.
      Hence I tried to reverse the git pull via git reset --hard f14e956 which unfortunately did not help either.
      Besides this, I previously ran the standard apt update && upgrade -y. However, the mirror worked fine when restarting after this via pm2 restart mm. S o I do not think it was based of this.
      For reference, I run MM on a Raspberry Pi 4.
        sdetweil @asd
        @asd ok, got it.
        you forgot the second step of upgrade
        git pull && npm install
        you MUST run npm install
        and POSSIBLY. have to run npm install or electron-rebuild in all the installed modules
        due to the possible nodejs change and electron change.
          asd @sdetweil
          @sdetweil awesome. It works again. Thank you very much. greatly appreciated!
          I have done my updates like this before and seem to have forgotten it this time.
            Roncham
            I have the same problem. I updated using
            git pull && npm run install-mm
            I also ran npm install in each module, only 1 seemed to update. Rebooted and still get same error:
            @raspberrypi:~/MagicMirror $ npm run start
            > magicmirror@2.23.0 start
            App threw an error during load
            Error: Cannot find module 'envsub'
            Require stack:
                at Module._resolveFilename (node:internal/modules/cjs/loader:963:15)
                at n._resolveFilename (node:electron/js2c/browser_init:2:109416)
                at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                at Module._load (node:internal/modules/cjs/loader:811:27)
                at f._load (node:electron/js2c/asar_bundle:2:13328)
                at Module.require (node:internal/modules/cjs/loader:1035:19)
                at require (node:internal/modules/cjs/helpers:102:18)
                at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:13:16)
                at Module._compile (node:internal/modules/cjs/loader:1141:14)
                at Module._extensions..js (node:internal/modules/cjs/loader:1196:10)
            A JavaScript error occurred in the main process
            Uncaught Exception:
            Require stack:
            MESA-LOADER: failed to retrieve device information
            MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
            failed to load driver: kms_swrast
            MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
            failed to load swrast driver
            ^C/home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
            Any other ideas?
              sdetweil @Roncham
              @Roncham I can only say that the npm run did not work
              from the MagicMirror folder do
              npm install --omit=dev
              R H 2 Replies Last reply Reply Quote 0
                Roncham @sdetweil
                @sdetweil said in Electron error: Cannot find module 'envsub':
                That worked thank you!
                • H Offline
                  hecaru @sdetweil
                  @sdetweil (posting it in case somebody else is going to need it)
                  In my case, the NPM error was:
                  npm ERR! code EBADENGINE
                  npm ERR! engine Unsupported engine
                  npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.31.0
                  npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.31.0
                  npm ERR! notsup Required: {"node":">=22.14.0"}
                  npm ERR! notsup Actual:   {"npm":"8.19.4","node":"v16.20.2"}
                  MagicMirror 2.31.0 needs at least Node 22, but through APT command, the Raspbian repos go up to 16. To solve this, I installed N, the Node version manager as an NPM module, then udpated Node that way.
                  $ sudo npm install -g n
                  added 1 package, and audited 2 packages in 2s
                  $ sudo n 22
                    installing : node-v22.14.0
                         mkdir : /usr/local/n/versions/node/22.14.0
                         fetch : https://nodejs.org/dist/v22.14.0/node-v22.14.0-linux-armv7l.tar.xz
                       copying : node/22.14.0
                     installed : v22.14.0 (with npm 10.9.2)
                  Note: the node command changed location and the old location may be remembered in your current shell.
                           old : /usr/bin/node
                           new : /usr/local/bin/node
                  If "node --version" shows the old version then start a new shell, or reset the location hash with:
                  hash -r  (for bash, zsh, ash, dash, and ksh)
                  rehash   (for csh and tcsh)
                  $ node -v
                  v16.20.2
                  $ hash -r
                  $ node -v
                  v22.14.0
                  Then rerun npm run install-mm and it will work.
                  Hope it helps. :)
                    sdetweil @hecaru
                    @hecaru yes, and IF you use my upgrade script, it will handle that for you…
                    same place as the install script
