    Resizing font size of modules
    26 Posts 3 Posters 19.6k Views 3 Watching
      sdetweil @Rags
      @Rags you are in the script section, not the body , click body, bottom left
      use the arrow top right to select the part of the MM screen (it will highlight as u move over it)
        Rags @sdetweil
          sdetweil @Rags
          @Rags expand the module_content element
          u are not selecting the title to view
          set the module refresh time to 60 seconds (updateInterval:60000) in config.js while you fiddle with the css
          I added a custom.css entry
          .newsfeed .newsfeed-title {
             font-size: 30px;
          you can see it was used here
          and the style medium (strikethru) has been overridden by something with font-size higher up.
            Rags @sdetweil
            @sdetweil i am sorry but i am unable to follow correctly what u are advising. However, the HTML code does not seem to contain the newsfeed title descrp. nf32023-04-26_20-53-20.png
            i think i selected the module content to expand, and i also changed the custom.css entry as suggested. The style display window is not showing the newsfeed entry. I am again not sure if i am doing the right thing. Anyways i am learning as we go.
            On second thoughts the process of changing the font size is so tedious (as it seems to me now), I wonder if there is an alternate way.
              sdetweil @Rags
              @Rags but you didn’t select the actual content (note that it is replaced every updateInterval time cycle… )
              if u aren’t looking at the actual element, then you won’t see its classes and styles…
              sometimes this is tedious work.
              here is an updated image with the areas selected in white,
              highlighted content (left screen)
              expanded document w selected content (middle)
              class tree (right)
              and I used the mouse pointer (pink) to allow highlight and click on the newsfeed title
              and you can test type the styles in the top box, (green) , to make sure they are right, before you copy/paste that section to the custom.css
                Rags @sdetweil
                After struggling, this is what i managed to take a screenshot of. It does not show the styles of the selected content in the dev screen.
                M S 3 Replies Last reply Reply Quote 0
                  MMRIZE @Rags
                  @Rags
                  It means your CSS(probably custom.css) is not applied.
                  The reasons might be;
                  • Fail to load custom.css (invalid file name or location)
                  • Syntax error in your custom.css
                  I can see the red circled X mark in your console. You can check it in Console tab(right of Elements tab) or click that mark directly.
                    MMRIZE @Rags
                    @Rags
                    To make things simple;
                    1. All other modules except newsfeed, remove or disable them. (It seems you have more than 28 modules currently)
                      disabled: true, // <-- toggle the module disabled/enabled
                      module: "weather",
                    1. Return to custom.css to the original, or remove all its contents.
                    2. Now, I’ll assume you have a clean CSS.
                    3. Then just add this into your custom.css and save it.
                      font-size: 60px;
                    .newsfeed .newsfeed-source {
                      font-size: 40px;
                    1. Let’s see what happens when MM runs.
                      sdetweil @Rags
                      @Rags using your image, marked up for color
                      the styles tree pane (right side, orange) shows info for only ONE element at a time
                      look at the bottom row of the element tree pane(left side, blue), right edge, says u have the module-content element selected (purple), not the newsfeed-title element(green)
                      because the module replaces it’s content every updateInterval cycle, the developers window will reselect the first element not replaced if your selected element disappears
                      that’s why I said set the interval to 60 seconds to give u time to look and change
                        Rags @sdetweil
                        @MMRIZE Finally ! Finally…
                        I disabled all modules, except newsfeed, then cleared out the custom.css configs and added a fresh config for newsfeed as suggested above and finally it worked.
                        So was the issue just because of the corrupt custom.css?
                        Anyways, this issue has enabled me to learn working with the developer console. I am glad.
                        Thank you @MMRIZE and thank you @sdetweil . Ever obliged.
                          sdetweil @Rags
                          @Rags glad u got it working
                          one thing to note, if there is a syntax error in the custom.css, everything ABOVE the error will work, everything AFTER will not
                            Rags @sdetweil
                            @sdetweil Sure noted. Thanks
