    MMM-CalendarExt3 Formatting questions
    14 Posts 3 Posters 4.5k Views 3 Watching
      Studio472
      These questions are about making the most of the space I have available.
      MMM-CalendarExt3:
      • How can I change the time format? I only see a section to change locale, not specific format.
      • Can the colored ‘dot’ or icon be removed?
      • Can an event span 2 rows? dot & time on row 1, name on row 2?
      M 3 Replies Last reply Reply Quote 0
        MMRIZE @sdetweil
        @sdetweil said in MMM-CalendarExt3 Formatting questions:
        .CX3 instead of .MMM-CalendarExt3
        Of course, .MMM-CalendarExt3 instead of .CX3 would work with the same priority. I just want to type less. :D
        .MMM-CalendarExt3 .event .title { ... } /* specificity: 0-3-0 */
        and
        .CX3 .event .title { ... } /* specificity: 0-3-0 */
        both would have the same priority(specificity), so anything would be ok.
          MMRIZE @Studio472
          @Studio472
          Generally, the time format depends on its locale. If you want to change the format by force, use eventTimeOptions. Javascript standard object Intl is used. See https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Intl/DateTimeFormat/DateTimeFormat#parameters
          For example;
          locale: "en-US",
          eventTimeOptions: {hour: "numeric", hour12: true},
          will show like this;
          locale: "en-US",
          eventTimeOptions: {hour: "2-digit", hour12: false},
          Under some locales, it will display different format.
          locale: "ko-KR",
          Or you can handle it with CSS Juggling, For example;
          locale: "en-US",
           eventTimeOptions: {timeStyle: "short"},
          And append this to your custom.css
          .CX3 .event .eventTimeParts.dayPeriod {
            display: none;
          .CX3 .event .eventTimeParts.hour {
            font-weight: bold;
            color: coral;
          Then you can get like this;
            MMRIZE @Studio472
            @Studio472 said in MMM-CalendarExt3 Formatting questions:
            Add this to your custom.css
            .CX3 .event .headline.useSymbol .symbol {
              display: none;
              MMRIZE @Studio472
              @Studio472
              I don’t recommend this.
              I don’t like this because it’s ugly and wasting space. And not easy to glance at and hard to recognize events.
              So that’s why I have been hiding this.
              Anyway, if you really want despite my warning; Append this to your custom.css
              .CX3 .eventContainer {
                height: calc(var(--eventheight) * var(--maxeventlines) * 2);
              .CX3 .cellContainer,
              .CX3 .week,
              .CX3 .cell {
                height: calc(var(--cellheaderheight) + var(--cellfooterheight) + calc(var(--eventheight) * var(--maxeventlines) * 2));
              .CX3 .event {
                align-items: flex-start
              .CX3 .event .headline .title {
                flex-basis: 100%;
              .CX3 .event .headline {
                flex-wrap: wrap;
              I dare to say still the original one-line approach is the better, without question;
                Studio472 @MMRIZE
                @MMRIZE This worked for me, thanks!
                  Studio472 @MMRIZE
                  @MMRIZE This did not work for me. However, I was able to find the code in the css file and comment out the style that inserted the icon/symbol.
                  I don’t have a ‘custom.css’ file. Are you referring to the “MMM-CalendarExt3.css” file?
                    sdetweil @Studio472
                    create one
                    touch ~/MagicMirror/css/custom.css
                    if you had used my install script, it would have done this for you, see
                      Studio472 @MMRIZE
                      @MMRIZE I’m not sure the solution, I agree it’s not as pretty, but at least it is informative. Maybe I just need to un-bold my font to make better use of the space.
                      I am curious how you get the baseball icons in the event title. When I tried changing the icons, very few actually worked.
                        Studio472 @sdetweil
                        @sdetweil Didn’t realize it wasn’t part of the module css. I’m assuming this takes precedence over code in the individual module css files?
                        custom.css
                        color: blue
                        calendarext3.css
                        color: black
                        Is the color black or blue?
                          Studio472 @MMRIZE
                          @MMRIZE I should have said, ‘2 lines when necessary’. I agree it’s goofy on all events. Another idea is some kind of separator to distinguish 2-line events, make them easier to read.
