    Electron screen becomes blank after a period of time
    13 Posts 6 Posters 8.0k Views 6 Watching
      DDE12
      I am running MM 2.23.0 on a Pi 2 Model B Rev 1.2 with Bullseye and after about 15-20 minutes, the electron screen becomes blank. Output in the terminal around the time that this happens is just normal calendar [info] and MMM-Gas [log] messages about gas prices. I use VNC to access the Pi and start the mirror. I can still access the mirror in a browser when the electron screen goes blank. I do get the following errors when starting MM:
      [12932:0530/114907.863519:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
      [12904:0530/114907.961672:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
      Please let me know what further info I can provide to help troubleshoot. Thank you for taking a look at this.
        sdetweil @DDE12
        @DDE12 those are warnings we can’t suppress… nothing we can do… problem is not in MM code…
        when the mm screen goes black again , open the developers window
        ctrl-shift-i on the MM screen keyboard
        then select the console tab, and scroll up to any errors (usually red text )
        cannot do this remotely has to be on the screen where the problem occurred
        D 1 Reply Last reply
          DDE12 @sdetweil
          @sdetweil These are the only messages and probably not actually a problem:
          Your are using the deprecated config values ‘colored’. Please switch to ‘coloredSymbol’ & ‘coloredText’!
          start @ calendar.js:100
          [CX3] Module is not prepared yet, wait a while.
          getDom @ MMM-CalendarExt3Agenda.js:193
          getDom @ MMM-CalendarExt3.js:228
          If electron stops with Dev window closed, I cannot open it. If electron stops with Dev window open, there is a message “DevTools was disconnected from the page…”
          If this is not a clue to aid in the troubleshooting, please let me know what to try next to get you some more info. Thanks!
          S M 2 Replies Last reply
            sdetweil @DDE12
            @DDE12 yes, if the right code crashes, then dev window will die
            sometime npm start dev will allow you to see the error before it dies…
              MMRIZE @DDE12
              @DDE12
              Check whether some modules make unhandled exception error when it create DOM.
              This message might imply some other module fails to create DOM at its start. (I’ll fix the CX3* modules not so strict to other module’s failure soon.)
              By the way, It would be better;
              • Remove all modules from config
              • Then add one by one unless you meet the problem.
                DDE12 @MMRIZE
                @MMRIZE I updated MMCalendarExt3* and am not getting those messages. Thank you! I have done the troubleshooting you recommended and have discovered that it is MMM-Wallpaper when set to display NASA’s Astronomy Picture of the Day. The black screen does not occur when I set the wallpaper to Met Museum or Firetv. Should I start a new post on troubleshooting MMM-Wallpaper?
                  sdetweil @DDE12
                  @DDE12 yes, start a new topic, but it’s probably a picture format or size problem
                  I don’t know if wallpaper has anyvdebugging/logging
                  karsten13K 1 Reply Last reply
                  • karsten13K
                    karsten13 @sdetweil
                    I suspect it’s a problem of the pi, not enough memory …
                      miabaker
                      Hi, I have the same issue of electron screen becoming blank. I have tried some solutions but none worked. I have added a line of code in my main.js file that reloads the window every 10 minutes. This prevents the screen from going blank. Here is the code snippet:
                      // Create a new BrowserWindow instance
                      let win = new BrowserWindow(options);
                      // Load the index.html file
                      win.loadFile('index.html');
                      // Reload the window every 10 minutes
                      setInterval(() => {
                        win.reload();
                      }, 600000);
                      I hope this helps you keep your magic mirror running.
                      Regards, Mia from CodeIT
                        sdetweil @miabaker
                        @miabaker so, you should find the module that’s failing and fix that.
                          DDE12 @karsten13
                          @karsten13 You might have something there. I changed the source in MMM-Wallpaper from the HD NASA to regular NASA and it took several hours or more for it to go blank. I have had the same problem with other modules as well that seem to resolve when I make the update interval longer. I’ve stopped using the MMM-Wallpaper at this point but I’m hoping there is some further troubleshooting to identify if the Pi is the problem and explore for a solution.
                          BKeyportB 1 Reply Last reply
                          • BKeyportB
                            BKeyport Module Developer @DDE12
                            @DDE12 I’d suspect both of those modules aren’t handling server difficulties well from NASA…
                              sdetweil @BKeyport
                              @BKeyport also, there have been image size issues as well. many of the NASA images are huge
