    MMM-homeassistant-sensors Text Color
    11 Posts 3 Posters 4.0k Views 3 Watching
      sdetweil @scuppasteve
      @scuppasteve said in MMM-homeassistant-sensors Text Color:
      .module.MMM-homeassistant-sensors .dimmed {
      color: #FFFFFF;
      that one is wrong for sure
        scuppasteve
        I got it figured out, i appreciate the help in getting this figured out.
          color: #FFFFFF;
          @scuppasteve cool… how is that one different than your second one?
          • E Offline
            edd189 @sdetweil
            Any idea how I can change the text color of one specific word in this module?
            I want “peak” to be red, “shoulder” yellow, and “off-peak” green.
            I messed around with the custom.css file, but it doesnt look like it accepts conditional formatting.
              sdetweil @edd189
              @edd189 find the element, see if it has a class, if so use it
              if not, figure the html path to get there and use that
              either in custom.css
              each entry for magicmirror
              starts with the module name as a class
              .modulename xxxx {
                 styles
              xxx is a selector clause (selects the elements the enclosed styles will apply to
              they can be quite explicit…
              here is one from my MMM-Config module, to hide a generated element I don’t want to show
              .possibly-hidden-tab div:nth-child(2)  > div > div >div >ul >li:only-child >a[rel*="Item 1"] {
                display: none;
              I use this to remind me of the css selector clause elements
              https://www.w3schools.com/cssref/css_selectors.php
              there is currently no selector clause attribute that can examine the text content of an element… there is a spec proposal to extend .has() to allow text elements…
                sdetweil @edd189
                @edd189 other than the above, you would have to change the code
