    MMM-homeassistant-sensors Text Color
    11 Posts 3 Posters 4.0k Views 3 Watching
      scuppasteve @sdetweil
      I tried what you suggested and it didn’t seem to have an effect. Is there something that i need to do in the /css/main.css to make the /css/custom.css load?
        sdetweil @scuppasteve
        @scuppasteve no… custom.css is force loaded by the runtime.
        try a space between the module name and the .dimmed
          scuppasteve
          I tried the following to no effect, not sure what the issue is.
          wrapper.className = 'dimmed small';
          .module.MMM-homeassistant-sensors .dimmed {
            color: #FFFFFF;
          and
            color: #FFFFFF;
            @scuppasteve said in MMM-homeassistant-sensors Text Color:
            color: #FFFFFF;
            that one is wrong for sure
              scuppasteve
              I got it figured out, i appreciate the help in getting this figured out.
                color: #FFFFFF;
                @scuppasteve cool… how is that one different than your second one?
                • E Offline
                  edd189 @sdetweil
                  Any idea how I can change the text color of one specific word in this module?
                  I want “peak” to be red, “shoulder” yellow, and “off-peak” green.
                  I messed around with the custom.css file, but it doesnt look like it accepts conditional formatting.
                    sdetweil @edd189
                    @edd189 find the element, see if it has a class, if so use it
                    if not, figure the html path to get there and use that
                    either in custom.css
                    each entry for magicmirror
                    starts with the module name as a class
                    .modulename xxxx {
                       styles
                    xxx is a selector clause (selects the elements the enclosed styles will apply to
                    they can be quite explicit…
                    here is one from my MMM-Config module, to hide a generated element I don’t want to show
                    .possibly-hidden-tab div:nth-child(2)  > div > div >div >ul >li:only-child >a[rel*="Item 1"] {
                      display: none;
                    I use this to remind me of the css selector clause elements
                    https://www.w3schools.com/cssref/css_selectors.php
                    there is currently no selector clause attribute that can examine the text content of an element… there is a spec proposal to extend .has() to allow text elements…
                      sdetweil @edd189
                      @edd189 other than the above, you would have to change the code
