    MMM-homeassistant-sensors Text Color
    11 Posts 3 Posters 4.1k Views 3 Watching
      scuppasteve
      So i have this module working great, but the text is grey and is almost invisible. I tried to edit it via custom.css. Any advice would be great.
      My custom.css looks like this:
      .MMM-homeassistant-sensors {
        color: #FFFFFF;
        sdetweil @scuppasteve
        @scuppasteve said in MMM-homeassistant-sensors Text Color:
        u need the class name of the text… u are going to override the class values…
        wrapper.className = ‘dimmed small’;
        .MMM-homeassistant-sensors.dimmed {
        color: #FFFFFF;
          scuppasteve @sdetweil
          I tried what you suggested and it didn’t seem to have an effect. Is there something that i need to do in the /css/main.css to make the /css/custom.css load?
            @scuppasteve no… custom.css is force loaded by the runtime.
            try a space between the module name and the .dimmed
              scuppasteve
              I tried the following to no effect, not sure what the issue is.
              wrapper.className = 'dimmed small';
              .module.MMM-homeassistant-sensors .dimmed {
                color: #FFFFFF;
              and
                color: #FFFFFF;
                color: #FFFFFF;
                that one is wrong for sure
                  scuppasteve
                  I got it figured out, i appreciate the help in getting this figured out.
                    color: #FFFFFF;
                    @scuppasteve cool… how is that one different than your second one?
                    • E Offline
                      edd189 @sdetweil
                      Any idea how I can change the text color of one specific word in this module?
                      I want “peak” to be red, “shoulder” yellow, and “off-peak” green.
                      I messed around with the custom.css file, but it doesnt look like it accepts conditional formatting.
                        sdetweil @edd189
                        @edd189 find the element, see if it has a class, if so use it
                        if not, figure the html path to get there and use that
                        either in custom.css
                        each entry for magicmirror
                        starts with the module name as a class
                        .modulename xxxx {
                           styles
                        xxx is a selector clause (selects the elements the enclosed styles will apply to
                        they can be quite explicit…
                        here is one from my MMM-Config module, to hide a generated element I don’t want to show
                        .possibly-hidden-tab div:nth-child(2)  > div > div >div >ul >li:only-child >a[rel*="Item 1"] {
                          display: none;
                        I use this to remind me of the css selector clause elements
                        https://www.w3schools.com/cssref/css_selectors.php
                        there is currently no selector clause attribute that can examine the text content of an element… there is a spec proposal to extend .has() to allow text elements…
                          sdetweil @edd189
                          @edd189 other than the above, you would have to change the code
