    UnhandledPromiseRejectionWarning: Error: Cannot find module 'request'
    3 Posts 2 Posters 1.6k Views 2 Watching
      maxaron
      Hi
      After updating to latest MagicMirror I have issues with “MMM-CalendarWeek”.
      From my terminal when running:
      > magicmirror@2.23.0 start
      [12.06.2023 18:40.30.551] [LOG]   Starting MagicMirror: v2.23.0
      [12.06.2023 18:40.30.564] [LOG]   Loading config ...
      [12.06.2023 18:40.30.580] [DEBUG] config template file not exists, no envsubst
      [12.06.2023 18:40.30.602] [LOG]   Loading module helpers ...
      [12.06.2023 18:40.30.604] [LOG]   No helper found for module: clock.
      [12.06.2023 18:40.30.606] [LOG]   No helper found for module: weather.
      [12.06.2023 18:40.30.635] [ERROR] (node:6065) UnhandledPromiseRejectionWarning: Error: Cannot find module 'request'
      Require stack:
      - /home/pi/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/node-ical.js
      - /home/pi/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/index.js
      - /home/pi/MagicMirror/modules/MMM-CalendarWeek/calendarfetcher.js
      - /home/pi/MagicMirror/modules/MMM-CalendarWeek/node_helper.js
          at Module._resolveFilename (node:internal/modules/cjs/loader:963:15)
          at n._resolveFilename (node:electron/js2c/browser_init:2:109751)
          at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (node:internal/modules/cjs/loader:811:27)
          at f._load (node:electron/js2c/asar_bundle:2:13330)
          at Module.require (node:internal/modules/cjs/loader:1035:19)
          at require (node:internal/modules/cjs/helpers:102:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/node-ical.js:2:15)
          at Module._compile (node:internal/modules/cjs/loader:1141:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1196:10)
          at Module.load (node:internal/modules/cjs/loader:1011:32)
          at Module._load (node:internal/modules/cjs/loader:846:12)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/index.js:3:12)
      (Use `electron --trace-warnings ...` to show where the warning was created)
      [12.06.2023 18:40.30.638] [ERROR] (node:6065) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
      [12.06.2023 18:40.30.896] [LOG]   Launching application.
      MESA-LOADER: failed to retrieve device information
      MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: kan inte öppna delad objektfil: Åtkomst nekas (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
      failed to load driver: kms_swrast
      MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: kan inte öppna delad objektfil: Åtkomst nekas (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
      failed to load swrast driver
      What am I doing wrong?
        sdetweil @maxaron
        @maxaron see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
        M 1 Reply Last reply
          maxaron @sdetweil
          @sdetweil You made my day / night! Thanks!
