Solved MMM-ImagesPhotos issue
@Nneuland see the link I posted on what to do. no research needed
https://forum.magicmirror.builders/topic/17845/mmm-imagesphotos-issue/2?_=1686706297079 -
Thank you Sam!!
@Nneuland are you back up and running?
I’m gonna give it a go later tonight -
After following your basic instructions I’m still having the issue.To clarify, after adding the modules config information, the mirror wont start up… removing the config information and saving auto starts the mirror.
@Nneuland correct, did you add the missing library request??
the link says,
read the messages output by MM at startup (which you showed above)
find the not found message, which has the library name in ituse the library name in an
npm install library_name_here
command while the current folder is the module folder
I am trying to teach you how to resolve this on your own next time… vs just giving u the answer, and having to do that over and over
Got it! Solved!
Sam, I can’t thank you enough for your time and patience. I appreciate all of your help. Over the years even!
I dont mean to be an annoyance. I find these issues daunting and beyond understanding at times.
