    Updating MM fails
    2 Posts 2 Posters 1.2k Views 2 Watching
      droidus
      Here is what is happening:
       git pull && npm run install-mm
      hint: Pulling without specifying how to reconcile divergent branches is
      hint: discouraged. You can squelch this message by running one of the following
      hint: commands sometime before your next pull:
      hint:
      hint:   git config pull.rebase false  # merge (the default strategy)
      hint:   git config pull.rebase true   # rebase
      hint:   git config pull.ff only       # fast-forward only
      hint:
      hint: You can replace "git config" with "git config --global" to set a default
      hint: preference for all repositories. You can also pass --rebase, --no-rebase,
      hint: or --ff-only on the command line to override the configured default per
      hint: invocation.
      error: Could not read a2d7cdcfb425c2a51715bbaf663c2feb267a9798
      error: Could not read b716ec33d99924733e8603ca5a657c83bf8cca26
      remote: Enumerating objects: 1230, done.
      remote: Counting objects: 100% (1166/1166), done.
      remote: Compressing objects: 100% (495/495), done.
      remote: Total 856 (delta 589), reused 543 (delta 318), pack-reused 0
      Receiving objects: 100% (856/856), 504.39 KiB | 2.61 MiB/s, done.
      Resolving deltas: 100% (589/589), completed with 156 local objects.
      fatal: revision walk setup failed
      error: https://github.com/MichMich/MagicMirror.git did not send all necessary objects
        sdetweil @droidus
        @droidus did u perchance checkout the develop branch before to fix a problem.
        best way to get out of this,
        rename the MagicMirror folder to MagicMirror.2
        install MagicMirror using my script
        see https://github.com/sdetweil/MagicMirror_scripts
        the in the new magic mirror temporarily rename the module defaults folder to something else, so this copy command does write over anything
        cd ~/MagicMirror/modules
        mv defaults temp
        copy the old mm module folder content here in the mm’s module folder, including the old defaults folder
        cp -r -p ~/MagicMirror.2/modules/ .
        (dot at the end means here)
        delete the defaults folder that was copied
        rm -rf defaults
        restore the new defaults folder
        mv temp defaults
        then copy your old config.js and custom.css from the old MagicMirror.2 folder over to the new one
