    PIR problem RPi 4B, Bullseye 64 bit
    23 Posts 3 Posters 6.6k Views 3 Watching
    • W Offline
      wyovino @sdetweil
      @sdetweil I followed the instructions for the manual install and I’m using pm2. MagicMirror is working as expected, but I just can’t get my python script which stops and starts the monitor based on input from a PIR sensor to work unless I stop Magic Mirror, start my program, and then restart MagicMirror.
      At this point I’m thinking of starting from scratch with the previous version of Raspberry Pi OS (Buster) which I believe works with a PIR module for Magic Mirror. That uses TVservice which does not work with Bullseye.
        sdetweil @wyovino
        @wyovino
        show me the output of
        pm2 status
        • W Offline
          wyovino @sdetweil
          $ pm2 status
          │ id │ name  │ mode     │ ↺   │ status    │ cpu     │ memory
          │ 0  │ mm    │ fork     │ 0   │ online    │ 0%       │ 2.8mb
            sdetweil @wyovino
            @wyovino said in PIR problem RPi 4B, Bullseye 64 bit:
            │ 0 │ mm
            so the managed app name is mm
            and the managed app number is 0
            so, now, show me the output of pm2 info 0, or pm2 info mm
            from my system
            (base) sam@sams:~/MagicMirror$ pm2 info 1
             Describing process with id 1 - name MagicMirror
            │ status            │ stopped                                   │
            │ name              │ MagicMirror                               │
            │ namespace         │ default                                   │
            │ version           │ 2.15.0                                    │
            │ restarts          │ 27                                        │
            │ uptime            │ 0                                         │
            │ script path       │ /home/sam/MagicMirror/installers/mm.sh
            particularly the script path
              headed to bed, will look in in the morning
              • W Offline
                wyovino @sdetweil
                @sdetweil pm2 info mm
                 Describing process with id 0 - name mm
                │ status            │ online                          │
                │ name              │ mm                              │
                │ version           │ N/A                             │
                │ restarts          │ 0                               │
                │ uptime            │ 29m                             │
                │ script path       │ /home/pi/mm.sh                  │
                │ script args       │ N/A                             │
                │ error log path    │ /home/pi/.pm2/logs/mm-error.log │
                │ out log path      │ /home/pi/.pm2/logs/mm-out.log   │
                │ pid path          │ /home/pi/.pm2/pids/mm-0.pid     │
                │ interpreter       │ bash                            │
                │ interpreter args  │ N/A                             │
                │ script id         │ 0                               │
                │ exec cwd          │ /home/pi                        │
                │ exec mode         │ fork_mode                       │
                │ node.js version   │ N/A                             │
                │ node env          │ N/A                             │
                │ watch & reload    │ ✘                               │
                │ unstable restarts │ 0                               │
                │ created at        │ 2023-06-28T02:47:15.904Z
                I tried putting the command in /home/pi/mm.sh but it’s not working.
                  sdetweil @wyovino
                  @wyovino maybe python needs some path info, env setup
                  • W Offline
                    wyovino @sdetweil
                    @sdetweil It’s running the program but the commands to control the monitor are ignored, The program is logging the activity. Here is the scenario that works:
                    Boot the Pi
                    Connect via SSH and issue command “pm2 stop mm”
                    Connect directly to the Pi using a connected keyboard and start my PIR program, then enter “pm2 start mm”
                    This works but is obviously inconvenient as I need to have a keyboard connected to the Magic Mirror. I’m going to see if I can run my program from crontab under the “pi” account. Maybe that’s the issue.
                      sdetweil @wyovino
                      @wyovino what do the pm2 logs show?
                      stop mm via pm2
                      pm2 stop all
                      pm2 flush – clear old logs
                      pm2 start 0
                      pm2 logs --lines=50
                      W 2 Replies Last reply Reply Quote 0
                      • W Offline
                        wyovino @sdetweil
                        pm2 logs --lines=50
                        [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
                        /home/pi/.pm2/pm2.log last 50 lines:
                        PM2 | 2023-07-06T10:26:31: PM2 log: App [mm:0] starting in -fork mode-
                        PM2 | 2023-07-06T10:26:31: PM2 log: App [mm:0] online
                        /home/pi/.pm2/logs/mm-out.log last 50 lines:
                        0|mm |
                        0|mm | > magicmirror@2.23.0 start
                        0|mm | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                        0|mm |
                        0|mm | [06.07.2023 10:26.34.272] [LOG] Starting MagicMirror: v2.23.0
                        0|mm | [06.07.2023 10:26.34.280] [LOG] Loading config …
                        0|mm | [06.07.2023 10:26.34.284] [DEBUG] config template file not exists, no envsubst
                        0|mm | [06.07.2023 10:26.34.290] [LOG] Loading module helpers …
                        0|mm | [06.07.2023 10:26.34.292] [LOG] No helper found for module: alert.
                        0|mm | [06.07.2023 10:26.34.309] [LOG] Initializing new module helper …
                        0|mm | [06.07.2023 10:26.34.310] [LOG] Module helper loaded: updatenotification
                        0|mm | [06.07.2023 10:26.34.311] [LOG] No helper found for module: clock.
                        0|mm | [06.07.2023 10:26.34.318] [LOG] Initializing new module helper …
                        0|mm | [06.07.2023 10:26.34.319] [LOG] Module helper loaded: MMM-MyScoreboard
                        0|mm | [06.07.2023 10:26.34.550] [LOG] Initializing new module helper …
                        0|mm | [06.07.2023 10:26.34.553] [LOG] Module helper loaded: calendar
                        0|mm | [06.07.2023 10:26.34.555] [LOG] No helper found for module: weather.
                        0|mm | [06.07.2023 10:26.34.592] [LOG] Initializing new module helper …
                        0|mm | [06.07.2023 10:26.34.593] [LOG] Module helper loaded: newsfeed
                        0|mm | [06.07.2023 10:26.35.237] [LOG] Initializing new module helper …
                        0|mm | [06.07.2023 10:26.35.238] [LOG] Module helper loaded: MMM-Jast
                        0|mm | [06.07.2023 10:26.35.238] [LOG] All module helpers loaded.
                        0|mm | [06.07.2023 10:26.35.252] [LOG] Starting server on port 8080 …
                        0|mm | [06.07.2023 10:26.35.462] [LOG] Server started …
                        0|mm | [06.07.2023 10:26.35.463] [LOG] Connecting socket for: updatenotification
                        0|mm | [06.07.2023 10:26.35.466] [LOG] Starting module helper: updatenotification
                        0|mm | [06.07.2023 10:26.35.467] [LOG] Connecting socket for: MMM-MyScoreboard
                        0|mm | [06.07.2023 10:26.35.468] [LOG] Starting node_helper for module [MMM-MyScoreboard]
                        0|mm | [06.07.2023 10:26.35.831] [LOG] Connecting socket for: calendar
                        0|mm | [06.07.2023 10:26.35.831] [LOG] Starting node helper for: calendar
                        0|mm | [06.07.2023 10:26.35.832] [LOG] Connecting socket for: newsfeed
                        0|mm | [06.07.2023 10:26.35.833] [LOG] Starting node helper for: newsfeed
                        0|mm | [06.07.2023 10:26.35.834] [LOG] Connecting socket for: MMM-Jast
                        0|mm | [06.07.2023 10:26.35.834] [LOG] MMM-Jast helper method started…
                        0|mm | [06.07.2023 10:26.35.836] [LOG] Sockets connected & modules started …
                        0|mm | [06.07.2023 10:26.35.876] [LOG] Launching application.
                        0|mm | [06.07.2023 10:26.38.724] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/wyovino%40gmail.com/private-b71db2843aaff911c63405db3b5da429/basic.ics - Interval: 300000
                        0|mm | [06.07.2023 10:26.38.762] [LOG] Create new newsfetcher for url: https://www.yahoo.com/news/rss - Interval: 300000
                        0|mm | [06.07.2023 10:26.38.769] [LOG] Create new newsfetcher for url: https://www.mlb.com/mets/feeds/news/rss.xml?_gl=1*1hyw7gs*_gcl_au*MTM2MjI0OTI5My4xNjgyMzQ1ODU3 - Interval: 300000
                        0|mm | [06.07.2023 10:26.38.773] [LOG] Create new newsfetcher for url: https://api.foxsports.com/v2/content/optimized-rss?partnerKey=MB0Wehpmuj2lUhuRhQaafhBjAJqaPU244mlTDK1i&aggregateId=7f83e8ca-6701-5ea0-96ee-072636b67336 - Interval: 300000
                        0|mm | [06.07.2023 10:26.40.378] [INFO] Newsfeed-Fetcher: Broadcasting 50 items.
                        0|mm | [06.07.2023 10:26.40.491] [INFO] Newsfeed-Fetcher: reloadInterval set to ttl=10800000 for url https://api.foxsports.com/v2/content/optimized-rss?partnerKey=MB0Wehpmuj2lUhuRhQaafhBjAJqaPU244mlTDK1i&aggregateId=7f83e8ca-6701-5ea0-96ee-072636b67336
                        0|mm | [06.07.2023 10:26.40.517] [INFO] Newsfeed-Fetcher: Broadcasting 25 items.
                        0|mm | [06.07.2023 10:26.40.779] [INFO] Checking git for module: MMM-MyScoreboard
                        0|mm | [06.07.2023 10:26.40.846] [INFO] Newsfeed-Fetcher: Broadcasting 75 items.
                        0|mm | [06.07.2023 10:26.40.861] [INFO] Checking git for module: MMM-Jast
                        0|mm | [06.07.2023 10:26.40.891] [INFO] Checking git for module: MagicMirror
                        0|mm | [06.07.2023 10:26.41.016] [INFO] Calendar-Fetcher: Broadcasting 1 events.
                        /home/pi/.pm2/logs/mm-error.log last 50 lines:
                        0|mm | MESA-LOADER: failed to retrieve device information
                        0|mm | MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/aarch64-linux-gnu/dri:$${ORIGIN}/dri:/usr/lib/dri)
                        0|mm | failed to load driver: kms_swrast
                        0|mm | MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/aarch64-linux-gnu/dri:$${ORIGIN}/dri:/usr/lib/dri)
                        0|mm | failed to load swrast driver
                        0|mm | [06.07.2023 10:26.41.236] [WARN] API request for IXIC failed: Quote not found for ticker symbol: IXIC
                        0|mm | [06.07.2023 10:26.43.980] [ERROR] Failed to retrieve repo info for MagicMirror: Error: Command failed: cd /home/pi/MagicMirror/ && git fetch -n --dry-run
                        0|mm | error: object file .git/objects/94/aeda9d76a88f9691fbebf7f4f50a39887c626e is empty
                        0|mm | fatal: loose object 94aeda9d76a88f9691fbebf7f4f50a39887c626e (stored in .git/objects/94/aeda9d76a88f9691fbebf7f4f50a39887c626e) is corrupt
                        0|mm | fatal: unpack-objects failed
                        0|mm |
