    MMM-Pir upgrade problem
    3 Posts 2 Posters 724 Views 2 Watching
    • F Offline
      Freddy_boy
      I recently attempted to perform an update for the MMM-Pir module and it didn’t seem to work. I attempted the ‘npm run rebuild’ command, and now I am getting the following error message:
      FATAL: 1 needed library not loaded
      Here is what I am seeing when I attempt the rebuild:
      pi@raspberrypi:~/MagicMirror/modules/MMM-Pir $ npm run rebuild
      MMM-Pir@1.0.1 rebuild
      installer/rebuild.sh
      Welcome to MMM-Pir rebuild script
      This script will erase current build and reinstall it
      Do you want to continue ? [Y/n]
      Your choice: Y
      Deleting: package-lock.json node_modules
      Done.
      Upgrading EXT-Pir…
      HEAD is now at 97f6cc8 update for vulnerabilities security // add node v16.14.0 min requirement
      hint: Pulling without specifying how to reconcile divergent branches is
      hint: discouraged. You can squelch this message by running one of the following
      hint: commands sometime before your next pull:
      hint:
      hint: git config pull.rebase false # merge (the default strategy)
      hint: git config pull.rebase true # rebase
      hint: git config pull.ff only # fast-forward only
      hint:
      hint: You can replace “git config” with “git config --global” to set a default
      hint: preference for all repositories. You can also pass --rebase, --no-rebase,
      hint: or --ff-only on the command line to override the configured default per
      hint: invocation.
      Already up to date.
      Done.
      Reinstalling MMM-Pir…
      npm ERR! code EBADENGINE
      npm ERR! engine Unsupported engine
      npm ERR! engine Not compatible with your version of node/npm: @npmcli/fs@3.1.0
      npm ERR! notsup Not compatible with your version of node/npm: @npmcli/fs@3.1.0
      npm ERR! notsup Required: {“node”:“^14.17.0 || ^16.13.0 || >=18.0.0”}
      npm ERR! notsup Actual: {“npm”:“8.5.5”,“node”:“v17.9.0”}
      npm ERR! /home/pi/.npm/_logs/2023-07-11T23_00_51_522Z-debug-0.log
      What am I missing, and how can I fix this? Thanks in advance…
        sdetweil @Freddy_boy
        @Freddy_boy said in MMM-Pir upgrade problem:
        he updated his module to require node 16.14 minimum
        and one of the dependencies says it needs
        14.7
        16.13
        or greater than or equal to 18.0
        u are on 17.9
        I would guess upgrade to 18.0 at least
        the next release (Oct 1) of mm will move to 18 as 16 is end of life Sept 1.
        • F Offline
          Freddy_boy
          Beautiful. That solved the issue. Thanks for the quick response.
