    SocketNotification not working?
    5 Posts 3 Posters 1.3k Views 3 Watching
    • T Offline
      tjat
      S M 3 Replies Last reply Reply Quote 0
        sdetweil @tjat
        @tjat said in SocketNotification not working?:
        this.sendSocketNotification
        what does the ‘this’ point to ? to module helper instance or something else?
        • T Offline
          tjat @sdetweil
          @sdetweil - It’s within the main module we’re I’m creating the calendar event. I’m following the same syntax being used above, which is working. I’ll also caveat that I’m not really experienced with this stuff so likely am doing something dumb. Am I losing the “this” reference somehow? Appreciate the help
                this.sendSocketNotification("ADD_CALENDAR_EVENT", payload);
                this.message = "Adding event...";
                this.messageType = "info";
                this.updateDom();
                this.closeForm();
                // TODO: Handle notifications
            if (notification === "EVENT_ADD_SUCCESS_MAIN") {
              console.log ("Sending event to calendar");
              this.showMessage('Event added!', 'success');
              if (payload) {
                this.sendNotification("EVENT_ADD_SUCCESS", payload);
              } else {
                this.sendNotification("EVENT_ADD_SUCCESS");
            } else if (notification === 'EVENT_ADD_FAILED') {
              this.showMessage('Event not added', 'error');
              if (payload) {
                this.sendNotification("EVENT_ADD_FAILED", payload);
              } else {
                this.sendNotification("EVENT_ADD_FAILED");
            MMRIZE @tjat
            @tjat
            Could you share the whole code in Git Hub?
              MMRIZE @tjat
              @tjat
              If your calendar object is defined in a named function, this will indicate the function itself. However in that case, sendSocketNotification would cause an undefined function error.
