    New 2-way mirror supplier - low prices and lead times
    76 Posts 17 Posters 100.2k Views 22 Watching
    • I
      Ivanov_d @tomster
      @tomster wow, just wow. Your setup looks gorgeous. Thank you very much for the thorough review. I have spoken to the mirror manufacturer and complained about the imperfect cut and they promised to calibrate their cutting machine. Can you tell us more.about your setup as MM doesn’t really have good smart home integration. I am using Home Assistant for my smart home backbone and until version 2021.8 I was able to stream sensor data to MM, but after the HA API has changed, I can’t find a decent MM plugin that works, so I would very much appreciate any advice.
      • T
        tomster @Ivanov_d
        I am using FHEM (fhem.de) as HAS and a corresponding front-end called FTUI3 (https://github.com/knowthelist/ftui) altered by myself to give a more MM2’ish look’n’feel. This originates many years ago when I started “automating” my house with retrofitting Homematic-devices and found that FHEM had a German-speaking community (and maintainer) along with easy integration of HM. Since then I simply stuck to FHEM though I am now using mostly KNX-devices. I must admit though that my understanding of a HAS is rather automating my house (as in my house does things by itself) rather than me having a fancy GUI to monitor and alter every setting from everywhere around the globe…
        FHEM might be much more on the coding-side than Home Assistant or other systems, but even I was able to get it to work the way I wanted it to. And I am by no means what you’d call a “coder” let alone having noteworthy Perl-skills. In the end I guess it’s the individual favour deciding which system to use.
        MM2 does have a FHEM-module but it is quite rudimentary and lacking many functions I wanted for my mirror. Besides I simply didn’t want to maintain 2 different systems.
          Daniels
          A while ago (somewhere in the middle of February) received the mirror, finally managed to put it together and take photos of it.
          I can totally agree with all the positive feedback written above my post from others.
          Experience with Denis was nice and I even received some tips on my planned cutouts with no additional costs 💪
          The mirror itself was ready in ~2 weeks and then shipped to me.
          It was well packaged and some of the packaging was actually useful for the final build for the parts behind the mirror.
          Shipping was done by DPD with tracking number and if I remember correctly was also insured.
          The build itself is quite simple with glass being pressed against wooden frame and the only cutout is for the display (sensor is at the very bottom of the mirror)
          Since the place is relatively dark the whole day, display is set to the lowest brightness, but in a room filled the daylight or lights on could easily bump it much higher without worrying that the illusion will be ruined by the backlight of the display
          Pictures bellow - do not get too confused by the mirror… in the mirror 😅
          Mirror in it’s best natural lightning conditions
          With screen turned off
          Mirror with lights on, same (lowest) screen brightness
          • I
            Ivanov_d
            mirror-in-mirror = mirrorception :D
            @Daniels nice setup, mate! Thank you for the positive feedback. It was a pleasure dealing with you as well.
            • I
              Ivanov_d
              I am still taking orders :) If anyone is interested, please PM me.
              • I
                Ivanov_d
                Update 24.04.2023:
                I am updating the price since I haven’t done so in two years and the prices have soared, unfortunately. The new price is 449 euro/sq. m.
                • I
                  Ivanov_d
                  The shipping company that I used to ship the mirrors got fully acquired by DPD and they changed their international shipping policy, now they won’t accept packages longer than 175 cm, therefore, the mirrors that I can ship cannot be over 165 cm due to the padding. I sent a 170 cm long mirror recently, however, I had to compromise the side padding, fortunately it arrived at the destination in one piece but it was a compromise that I don’t want to make anymore. I could use other companies, but their prices are x2 higher and I want to keep the cost to a minimum so more people can build their projects.
                  1 Reply Last reply Reply Quote -1
                  • I
                    Ivanov_d
                    Update 13.07.2023: I have decided that all money that I make from these mirrors (not just the profit - ALL MONEY) will go to different donations. So far, I have donated to three different campaigns for children with cancer.
                    I would like to ask whoever purchased mirror from me to post some feedback whether positive or negative so that others who are still thinking about it can make the right decision.
                      Maki
                      Hi Denis,
                      Im Intressted for a Glas in the size of 61x91 for this Ikea Ribbon Frame:
                      https://www.ikea.com/ch/de/p/ribba-rahmen-schwarz-90301621/
                      how much would that be if the shipping is to Switzerland?
                      Thanks!
                      • I
                        Ivanov_d @Maki
                        @Maki I will check with the supplier and will ping you over a PM, since they are in summer vacation until the middle of August. Do you have the frame with you to measure the inside mounting dimentions?
                          Maki @Ivanov_d
                            Maki @Ivanov_d
                            @Ivanov_d Alright, Thanks!
                            just measured it, it is actually 61x91 cm (inside dimensions for the glass)
                            • I
                              Ivanov_d @Maki
                              @Maki great. Sent a quote request. Will update you later about the price, but just FYI Switzerland is not a part of the EU and for some reason DPD does not offer any transportation options. UPS, however, does, at triple the price - just the shipping estimate would be around 180 EUR. Just letting you know before hand.
                                Maki @Ivanov_d
                                @Ivanov_d damn, always the same… since im near to the Austrian border i can ask a co worker who lives in austria, guessing that would be the better option:)
                                • I
                                  Ivanov_d @Maki
                                  @Maki definitely. To Austria, the shipping would be only 30 EUR :)
                                  T M 2 Replies Last reply Reply Quote 0
                                  • T
                                    Temneanu @Ivanov_d
                                    @Ivanov_d
                                    Is there any chance to have delivery in Ireland?
                                      Maki @Ivanov_d
                                      @Ivanov_d Great, just talked to him, hes fine with it:)
                                      • I
                                        Ivanov_d @Temneanu
                                        @Temneanu yes, but you won’t like the shipping cost. It is around 150-200 EUR.
                                        • T
                                          Temneanu @Ivanov_d
                                          @Ivanov_d ok
                                          Thank you very much
                                          • E
                                            ernade @Ivanov_d
                                            @Ivanov_d said in New 2-way mirror supplier - lower prices and lead times:
                                            @ernade said in New 2-way mirror supplier - lower prices and lead times:
                                            could you tell how much will cost for a 50x40 cm to ship to Italy?
                                            The price would be 59,80 EUR for the mirror and you can choose the shipping method:
                                            • Option 1 - Bulgarian Posts - 33,21 EUR
                                            • Option 2 - DPD - 39,49 EUR
                                            Sorry, it was a long time ago. Do you think those prices are still correct up to now?
                                            • 3 / 4
