    MMM-Flights no map ist shown
    9 Posts 2 Posters 1.3k Views 2 Watching
    • O Offline
      OmaBosselt @karsten13
      @karsten13
      I’ll take a close look at the logs.
      What exactly are your openmaps settings? Then I’ll test them. I have selected the same section in the config as with Flightradar. Should that be the problem? It can only be something really stupid…maybe I got bogged down there.
      You don’t know…
      LG
      Sabine
      • karsten13K Offline
        karsten13 @OmaBosselt
        @OmaBosselt
        I’m testing with an empty config:
              module: "MMM-Flights",
        May you can try this to see if it changes something …
          karsten13 @karsten13
          can reproduce it if I use a nonexisting mapUrl, so I think you have a typo in your mapUrl …
          O 1 Reply Last reply Reply Quote 1
          • O Offline
            @karsten13
            but into the line mapUrl: “https://{a-c}.tile.openstreetmap.de/{z}/{x}/{y}.png”
            and therefore could not have been caused by a typing error. I will check it anyway. You only have to enter the coordinates 2x in config.js and MMM-Flights.js.
            With openstreetmap I am not able to export my own map address. Somewhere I don’t understand something fundamental.
            • O Offline
              OmaBosselt @OmaBosselt
              @OmaBosselt
              Heureka or not but it works fine… for me. :o)
              mapFixedArea: true, // if set, the defined area is shown, if not the area is calculated from the plane locations
