    MMM-YoutubeChannelStats not showing anything
    2 Posts 2 Posters 447 Views 2 Watching
      Pjarki
      Im trying to use the module YoutubeChannelStats that picks up youtube channel stats from a youtube channel, such as follower count and view count. The module seems to run correctly and the mirror shows loading…but nothing else.
      Its one of the modules where you need to use a Google API and I have it all working on another device so I doubt those credentials (API Key and Channel ID) are wrong.
      When running the mirror I get this error, dont know if it is related or not:
      [1376:0822/181638.160309:ERROR:gl_surface_presenta
      tion_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
      And during installation of the module I get the following details after nmp audit:
      Severity: high
      minimatch ReDoS vulnerability - https://github.com/advisories/GHSA-f8q6-p94x-37v3
      fix available via npm audit fix --force
      Will install mocha@10.2.0, which is a breaking change
      node_modules/minimatch
      mocha 5.1.0 - 9.2.1
      Depends on vulnerable versions of minimatch
      Depends on vulnerable versions of nanoid
      node_modules/mocha
      nanoid 3.0.0 - 3.1.30
      Severity: moderate
      Exposure of Sensitive Information to an Unauthorized Actor in nanoid - https://github.com/advisories/GHSA-qrpm-p2h7-hrv2
      node_modules/nanoid
        sdetweil @Pjarki
        @Pjarki said in MMM-YoutubeChannelStats not showing anything:
        nah, thats from the opengl driver…
