    Module Intermittently Updating
    4 Posts 2 Posters 698 Views 2 Watching
      drstang
      I am a total novice with JS, but have re-arranged the weather module to display my home weather station data instead of OpenWeathers data. The module works, but I’m having issues with it intermittently updating the data. In other words, the module will work and update fine for several days (or hours) and then will stop updating, and will show the same data until I restart MM or the pi. The other modules work fine on the MM, and per the weather station API page, I’m not exceeding the call limits. Only error I’m seeing on my Chrome console is:
      “Uncaught SyntaxError: Unexpected end of JSON input
      at JSON.parse ()
      at weatherRequest1.onreadystatechange (MMM-AW.js:187:30)”,
      which to be honest I’m not sure what it means…
      Appreciate any help! My config is attached. ```
      Module.register(“MMM-AW”,{
      // Default module config.
      defaults: {
          applicationKey: "",
      	apiKey: "",
      	openWeatherMapLocationID: "",
      	openWeatherMapAPI: "",
      	units: config.units,
      	updateInterval: 5 * 60 * 1000, // every 10 minutes
      	animationSpeed: 1000,
      	timeFormat: config.timeFormat,
      	lang: config.language,
      	tableClass: "large",
      	showSun: true,
      	showIcons: true,
      	initialLoadDelay: 0, // 0 seconds delay
      	retryDelay: 2500,
      	apiBase: "https://rt.ambientweather.net/v1/devices",
      	apiBaseOWM: "https://api.openweathermap.org/data/2.5/weather?",
      	iconTable: {
      		"01d": "wi-day-sunny",
      		"02d": "wi-day-cloudy",
      		"03d": "wi-cloudy",
      		"04d": "wi-cloudy-windy",
      		"09d": "wi-showers",
      		"10d": "wi-rain",
      		"11d": "wi-thunderstorm",
      		"13d": "wi-snow",
      		"50d": "wi-fog",
      		"01n": "wi-night-clear",
      		"02n": "wi-night-cloudy",
      		"03n": "wi-night-cloudy",
      		"04n": "wi-night-cloudy",
      		"09n": "wi-night-showers",
      		"10n": "wi-night-rain",
      		"11n": "wi-night-thunderstorm",
      		"13n": "wi-night-snow",
      		"50n": "wi-night-alt-cloudy-windy"
      	iconImageTable: {
      		"01d": "sunny.png",
      		"02d": "partlysunny.png",
      		"03d": "partlycloudy.png",
      		"04d": "cloudy.png",
      		"09d": "sleet.png",
      		"10d": "rain.png",
      		"11d": "tstorms.png",
      		"13d": "snow.png",
      		"50d": "fog.png",
      		"01n": "nt_clear.png",
      		"02n": "nt_cloudy.png",
      		"03n": "nt_mostlycloudy.png",
      		"04n": "cloudy.png",
      		"09n": "nt_sleet.png",
      		"10n": "nt_rain.png",
      		"11n": "nt_tstorms.png",
      		"13n": "nt_snow.png",
      		"50n": "nt-alt-cloudy-windy.png"
      getScripts: function(){
      	return ["moment.js"];
      getStyles: function(){
      	return ["weather-icons.css", "MMM-AW.css"];
      start: function () {
      	moment.locale(config.language);
      	this.windSpeed = null;
      	this.windDirection = null;
      	this.sunriseSunsetTime = null;
      	this.sunriseSunsetIcon = null;
      	this.temperature = null;
      	this.weatherType = null;
      	this.feelsLike = null;
      	this.dailyRain = null;
      	this.loaded = false;
      	this.scheduleUpdate(this.config.initialLoadDelay);
      	this.updateTimer = null;
      getDom: function() {
      	wrapper.className = this.config.tableClass;
      	var medium = document.createElement("div");
      	medium.className = "normal medium";
      	var windIcon = document.createElement("span");
      	windIcon.className = "wi wi-strong-wind dimmed";
      	medium.appendChild(windIcon);
      	var windSpeed = document.createElement("span");
      	windSpeed.innerHTML = " " + this.windSpeed + "<span class=\"xsmall\">" + "mph" + "</span>";
      	medium.appendChild(windSpeed);
      	var windDirection = document.createElement("span");
      	windDirection.innerHTML = " " + this.windDirection;
      	medium.appendChild(windDirection);
      	var spacer = document.createElement("span");
      	spacer.innerHTML = "&nbsp;";
      	medium.appendChild(spacer);
      	if (this.config.showSun){
      		var sunriseSunsetIcon = document.createElement("span");
      		sunriseSunsetIcon.className = "wi dimmed " + this.sunriseSunsetIcon;
      		medium.appendChild(sunriseSunsetIcon);
      		var sunriseSunsetTime = document.createElement("span");
      		sunriseSunsetTime.innerHTML = "" + this.sunriseSunsetTime;
      		medium.appendChild(sunriseSunsetTime);
      	wrapper.appendChild(medium);
      	var large = document.createElement("div");
      	large.className = "large light";
      	if (this.config.showIcons){
      		var weatherIcon = document.createElement("span");
      		weatherIcon.innerHTML = this.weatherTypeTxt;
      		weatherIcon.classList.add("currentWeatherIconWrapper");
      		large.appendChild(weatherIcon);
      	var temperature = document.createElement("span");
      	temperature.className = "bright";
      	temperature.innerHTML = " " + this.temperature + "°";
      	large.appendChild(temperature);
      	wrapper.appendChild(large);
      	if(this.feelsLike !== null  || this.dailyRain !== null){
      	    var small1 = document.createElement("div");
      		small1.className = "normal small";
      		var feelsLike = document.createElement("span");
      		feelsLike.className = "dimmed";
      		feelsLike.innerHTML = "Feels like: "+ this.feelsLike + "°";
      		small1.appendChild(feelsLike);
      		small1.appendChild(spacer);
      		var dailyRain = document.createElement("span");
      		dailyRain.className = "dimmed";
      		dailyRain.innerHTML = "Daily Rain: "+ this.dailyRain + "<span class=\"xsmall\">" + "in" + "</span>";
      		small1.appendChild(dailyRain);
      		wrapper.appendChild(small1);
      	return wrapper;
      updateWeather: function() {
      	var url = this.config.apiBase + this.getParams();
      	var self = this;
      	var retry = true;
      	var weatherRequest = new XMLHttpRequest();
      	weatherRequest.open("GET", url, true);
      	weatherRequest.onreadystatechange = function() {
      		if (this.readyState === 4) {
      			if (this.status === 200) {
      				self.processWeather(JSON.parse(this.response));
      				if (self.config.showSun || self.config.showIcons){
      					var owmurl = self.config.apiBaseOWM + "id=" + self.config.openWeatherMapLocationID + "&appid=" + self.config.openWeatherMapAPI
      					var weatherRequest1 = new XMLHttpRequest();
      					weatherRequest1.open("GET", owmurl, true);
      					weatherRequest1.onreadystatechange = function(){
      						if (this.readyState ===4 || this.status === 200){
      							self.processSun(JSON.parse(this.response));
      					weatherRequest1.send();
      			} else if (this.status === 401) {
      				self.config.appid = "";
      				self.updateDom(self.config.animationSpeed);
      				Log.error(self.name + ": Incorrect APPID.");
      				retry = false;
      			} else if (this.status === 429){
      			    Log.error(self.name + ": Too many requests.");
      			    retry = false;
      			} else {
      				Log.error(self.name + ": Could not load weather.");
      			if (retry) {
      				self.scheduleUpdate((self.loaded) ? -1 : self.config.retryDelay);
      	weatherRequest.send();
      getParams: function() {
      	var params = "?";
      	params += "applicationKey=" + this.config.applicationKey;
      	params += "&apiKey=" + this.config.apiKey;
      	return params;
      processWeather: function(data) {
      	this.temperature = this.roundValue(data[0].lastData.tempf);
      	this.windSpeed = this.roundValue(data[0].lastData.windspeedmph);
      	this.windDirection = this.deg2Cardinal(data[0].lastData.winddir);
      	this.feelsLike = this.roundValue(data[0].lastData.feelsLike);
      	this.dailyRain = data[0].lastData.dailyrainin;
      	if(this.temperature!=='undefined'){Log.info(this.name + "Temperature is loaded:" + this.temperature)}
      	if(this.windSpeed!=='undefined'){Log.info(this.name + "Windspeed is loaded:" + this.windSpeed)}
      	if(this.windDirection!=='undefined'){Log.info(this.name + 'Wind Direction is loaded:' + this.windDirection)}
      	if(this.feelsLike!=='undefined'){Log.info(this.name + "Feels Like is Loaded:" + this.feelsLike)}
      	if (this.dailyRain!=='undefined'){Log.info(this.name + "Daily Rain is Loaded:" + this.dailyRain)};
      	this.loaded = true;
      	this.updateDom(this.config.animationSpeed);
      processSun: function(sunData) {
      	var now = new Date();
      	var sunrise = new Date(sunData.sys.sunrise * 1000);
      	var sunset = new Date(sunData.sys.sunset * 1000);
      	var sunriseSunsetDateObject = (sunrise < now && sunset > now) ? sunset : sunrise;
      	var timeString = moment(sunriseSunsetDateObject).format("h:mm a");
      	this.sunriseSunsetTime = timeString;
      	this.sunriseSunsetIcon = (sunrise < now && sunset > now) ? "wi-sunset" : "wi-sunrise";
      	this.weatherType = this.config.iconTable[sunData.weather[0].icon];
      	this.weatherTypeTxt = "<img src ='./modules/MMM-AW/img/" + this.config.iconImageTable[sunData.weather[0].icon] + "' style ='vertical-align:middle' class='currentWeatherIcon'>";
      	this.loaded = true;
      scheduleUpdate: function(delay) {
      	var nextLoad = this.config.updateInterval;
      	if (typeof delay !== "undefined" && delay >= 0) {
      		nextLoad = delay;
      	var self = this;
      	setTimeout(function() {
      		self.updateWeather();
      	}, nextLoad);
      deg2Cardinal: function(deg) {
      	if (deg>11.25 && deg<33.75){
      			return "NNE";
      	}else if (deg>33.75 && deg<56.25){
      			return "ENE";
      	}else if (deg>56.25 && deg<78.75){
      			return "E";
      	}else if (deg>78.75 && deg<101.25){
      			return "ESE";
      	}else if (deg>101.25 && deg<123.75){
      			return "ESE";
      	}else if (deg>123.75 && deg<146.25){
      			return "SE";
      	}else if (deg>146.25 && deg<168.75){
      			return "SSE";
      	}else if (deg>168.75 && deg<191.25){
      			return "S";
      	}else if (deg>191.25 && deg<213.75){
      			return "SSW";
      	}else if (deg>213.75 && deg<236.25){
      			return "SW";
      	}else if (deg>236.25 && deg<258.75){
      			return "WSW";
      	}else if (deg>258.75 && deg<281.25){
      			return "W";
      	}else if (deg>281.25 && deg<303.75){
      			return "WNW";
      	}else if (deg>303.75 && deg<326.25){
      			return "NW";
      	}else if (deg>326.25 && deg<348.75){
      			return "NNW";
      	}else{
      			 return "N";
      roundValue: function(temperature) {
      	return parseFloat(temperature).toFixed(1);
        sdetweil @drstang
        @drstang said in Module Intermittently Updating:
        at JSON.parse ()
        that means the code was expecting data from the source, in JSON format, and did not get it…
        means the code didn’t check for errors and recover from them.
        D 1 Reply Last reply
          drstang @sdetweil
          @sdetweil Ahh ok. Well that makes sense. And I guess that could also theoretically cause it to hang/not update…
          Appreciate it!
            sdetweil @drstang
            @drstang correct… once it fails like that, it will never recover… code died
