Solved MMM-GroveGestures / Python script is terminated
@Egnos said in MMM-GroveGestures / Python script is terminated:
Too long cabling, > 30cm. The signal would be weaker or noisy.
It will surely be longer, 40 or 50 cm
Hopefully not, over 30cm long cabling could be the issue. (You wrote 40~50cm, is it right?)
@MMRIZE Yes, from the GPIO to the sensor there will be about 40/45 cm…
@Egnos
40~45cm seems somewhat too long. Could you build it shorter? or use a lower frequency than usual case.
Ref. these; -
@MMRIZE The path of the sensor cables (Yellow, red, white and black) is this:
Maybe I could shorten the wires a bit…
Thanks for the links.
@Egnos Maybe Sparkfun Midpoint and Endpoint to give you ample length. They tout over 100’ with those devices.
@ankonaskiff17 said in MMM-GroveGestures / Python script is terminated:
Endpoint
Hi @ankonaskiff17, wich one of these?
https://www.sparkfun.com/categories/304?page=1 -
@Egnos
There are several “I2C Extenders” (Or “Active Terminator”)I haven’t tried this kind of thing, but it is worth researching.
@Egnos You want what is called a Midpoint which is
Also need an Endpoint which is thisI whipped this together in double quick time so pardon the lack of tidiness.
For reference sake I focused on a couple of BME688’s to give you sort of a benchmark.
First is screenshot showing both BME’s running. Had to do jumper on one to get a second address 0x76 and 0x77
![ScreenShot2.jpg](Input file contains unsupported image format) -
@ankonaskiff17 Here is screenshot of BME688 0x77
It is connected to one of my Endpoints. -
@ankonaskiff17 50 ft ethernet
And the money shot. 50 ft cable
