    MMM-CalendarExt3 how do you create multiple events with color css?
    17 Posts 4 Posters 6.0k Views 4 Watching
      Sam 0
      How do you create multiple events with color css?
      Is there an example of what this looks like?
      I now have the following and it works, but I don’t know how I want to add a second event, so in addition to outings, for example birthdays
      module: “MMM-CalendarExt3”,
      position: “lower_third”,
      title: “”,
      eventTransformer: (ev) => {
      if (ev.title.search(‘Uitje’) > -1) ev.color = ‘blue’
      return ev
      I also wonder how I can get a nice icon in an event, for example a birthday cake icon, does anyone have an example that I can look at?
        MMRIZE @Sam 0
        @Sam-0
        First,
        You can assign colour or class per each calendar. So check if your events are separated by different calendars. Check it first.
        In case your events are in one calendar and want to distinguish each by title of event, you can do this;
          if (ev.title.search('Uitje') > -1) ev.color = 'blue'
          if (ev.title.search('verjaardag' > -1) ev.icon = 'birthday-cake'
          /* and so on ... */
          return ev
        S 3 Replies Last reply Reply Quote 0
          Sam 0 @MMRIZE
          @MMRIZE said in MMM-CalendarExt3 how do you create multiple events with color css?:
          if (ev.title.search(‘verjaardag’ > -1) ev.icon = ‘birthday-cake’
          Thanks for your help, it went wrong at first because a bracket was missing.) I adjusted this but unfortunately it doesn’t work. Could this be related to the fact that I have already adjusted the CSS?
          title: “”,
          if (ev.title.search(‘Verjaardag’) > -1) ev.icon = ‘birthday-cake’
          return ev
            Sam 0 @MMRIZE
            @MMRIZE
              module: "MMM-CalendarExt3",
              position: "lower_third",
              title: "",
                          if (ev.title.search('Verjaardag') > -1) ev.icon = 'birthday-cake'
                          return ev
              sdetweil @Sam 0
              @Sam-0 I’ve edited your post…
              please try to include all the braces {}
              so it is completely clear
              and use indents to add clarity to what is where …
                Sam 0 @MMRIZE
                @MMRIZE
                I have removed the custom CSS so it is standard, but I do not see the icon but I do see the blue color.
                  MMRIZE @Sam 0
                  @Sam-0 sorry, it would not be ‘icon’, it would be ’ symbol’
                    Sam 0 @MMRIZE
                    @MMRIZE
                    So I see that Outing has turned blue, but I don’t see any other symbol for birthday.
                      sdetweil @Sam 0
                      @Sam-0 note the code should use symbol NOT icon
                        MMRIZE @Sam 0
                        @Sam-0
                        Sorry, the Previous version was not tested, I have shown the code only with my brain, not with a real device.
                        Here is the tested code.
                            if (ev.title.search('Uitje') > -1) ev.color = 'gold'
                            if (ev.title.search('Verjaardag') > -1) ev.symbol = ['birthday-cake']
                            return ev
                          Sam 0 @MMRIZE
                          @MMRIZE
                          Thank you very much for your effort. I try to describe as best as I can what is working now so that others can learn from it.
                          Okay, I did some further research based on the term symbol and saw that the symbols had to be added in the general calendar. I also saw them in MMM-CalendarExt3 as below.
                          Will show my config code here:
                          			header: "Familie agenda",
                          						symbol: "calendar-check",
                          						url: "outlook url"
                          customEvents: [
                              	{keyword: "zwemmen", symbol: "person-swimming fas fa-fw fa-person-swimming"},
                              	{keyword: "padel", symbol: "running fas fa-fw fa-running"},
                          	{keyword: "zingen", symbol: "music fas fa-fw fa-music"},
                          	{keyword: "verjaardag", symbol: "cake-candles fas fa-fw fa-cake-candles"},
                              	{keyword: "volleybal", symbol: "volleyball fas fa-fw fa-volleyball"}
                            title: "",
                             if (ev.title.search('Verjaardag') > -1) ev.color = '#FF69B4'
                          I will also try your previous code.
                          I would also like to control the color via CSS in the config file.
                          How are you doing this? I already tried something but this doesn’t seem to work.
                            Sam 0 @MMRIZE
                            @MMRIZE
                            I also tested your code and it works fine too.
                              MMRIZE @Sam 0
                              @Sam-0
                              If you have some knowledge about CSS, you can almost control the look of this module. Most needed info is described in readme md file.
                                MMRIZE @Sam 0
                                @Sam-0 said in MMM-CalendarExt3 how do you create multiple events with color css?:
                                That is why I said;
                                First,
                                BKeyportB S 2 Replies Last reply Reply Quote 0
                                • BKeyportB Offline
                                  BKeyport Module Developer @MMRIZE
                                  Here’s my multi-transform code for reference. (The brackets may be off, I didn’t check on copy…)
                                  					if (ev.title.search("🏠") > -1) {
                                  						ev.title = ev.title.replace("🏠 Personal Commitment","🏠 Personal Event");
                                  						ev.color = 'yellow';
                                  					if (ev.title.search("✈ Flight") > -1) {
                                  						ev.title = ev.title.replace("✈ Flight","🏠 Personal Event");
                                  					if (ev.title.search("busy") > -1) {
                                  						ev.title = ev.title.replace("busy","🏠 Mom Event");
                                  					if (ev.title.search("Weekley") > -1) {
                                  						ev.title = ev.title.replace("Weekley","Weekly");
                                  					return ev
                                  I’m using both CX3 and CX3A
                                    Sam 0 @MMRIZE
                                    First,
                                    I only have one calendar. I’ve already looked at an example but it doesn’t seem to work.
                                    I found this example on this forum.
                                    with customer.css
                                    .CX3 .Ben {
                                    color: brown;
                                    eventTransformer: function(ev) {
                                      if (ev.title.search(“Ben”) > -1)  ev.className = “Ben”;
                                      return ev
                                    This doesn’t seem to do much, the color just remains white.
                                    But is this possible?
                                      sdetweil @Sam 0
                                      @Sam-0 in the default calendar, where you put url:
                                      add
                                      color: … whatever
