    MMM-CalendarExt3 how do you create multiple events with color css?
    17 Posts 4 Posters 5.9k Views 4 Watching
      Sam 0 @MMRIZE
      @MMRIZE said in MMM-CalendarExt3 how do you create multiple events with color css?:
      if (ev.title.search(‘verjaardag’ > -1) ev.icon = ‘birthday-cake’
      Thanks for your help, it went wrong at first because a bracket was missing.) I adjusted this but unfortunately it doesn’t work. Could this be related to the fact that I have already adjusted the CSS?
      module: “MMM-CalendarExt3”,
      position: “lower_third”,
      title: “”,
      eventTransformer: (ev) => {
      if (ev.title.search(‘Uitje’) > -1) ev.color = ‘blue’
      if (ev.title.search(‘Verjaardag’) > -1) ev.icon = ‘birthday-cake’
      return ev
        Sam 0 @MMRIZE
        @MMRIZE
          module: "MMM-CalendarExt3",
          position: "lower_third",
          title: "",
                      if (ev.title.search('Uitje') > -1) ev.color = 'blue'
                      if (ev.title.search('Verjaardag') > -1) ev.icon = 'birthday-cake'
                      return ev
          sdetweil @Sam 0
          @Sam-0 I’ve edited your post…
          please try to include all the braces {}
          so it is completely clear
          and use indents to add clarity to what is where …
            Sam 0 @MMRIZE
            @MMRIZE
            I have removed the custom CSS so it is standard, but I do not see the icon but I do see the blue color.
              MMRIZE @Sam 0
              @Sam-0 sorry, it would not be ‘icon’, it would be ’ symbol’
                Sam 0 @MMRIZE
                @MMRIZE
                So I see that Outing has turned blue, but I don’t see any other symbol for birthday.
                  sdetweil @Sam 0
                  @Sam-0 note the code should use symbol NOT icon
                    MMRIZE @Sam 0
                    @Sam-0
                    Sorry, the Previous version was not tested, I have shown the code only with my brain, not with a real device.
                    Here is the tested code.
                        if (ev.title.search('Uitje') > -1) ev.color = 'gold'
                        if (ev.title.search('Verjaardag') > -1) ev.symbol = ['birthday-cake']
                        return ev
                      Sam 0 @MMRIZE
                      @MMRIZE
                      Thank you very much for your effort. I try to describe as best as I can what is working now so that others can learn from it.
                      Okay, I did some further research based on the term symbol and saw that the symbols had to be added in the general calendar. I also saw them in MMM-CalendarExt3 as below.
                      Will show my config code here:
                      			header: "Familie agenda",
                      						symbol: "calendar-check",
                      						url: "outlook url"
                      customEvents: [
                          	{keyword: "zwemmen", symbol: "person-swimming fas fa-fw fa-person-swimming"},
                          	{keyword: "padel", symbol: "running fas fa-fw fa-running"},
                      	{keyword: "zingen", symbol: "music fas fa-fw fa-music"},
                      	{keyword: "verjaardag", symbol: "cake-candles fas fa-fw fa-cake-candles"},
                          	{keyword: "volleybal", symbol: "volleyball fas fa-fw fa-volleyball"}
                        title: "",
                         if (ev.title.search('Verjaardag') > -1) ev.color = '#FF69B4'
                      I will also try your previous code.
                      I would also like to control the color via CSS in the config file.
                      How are you doing this? I already tried something but this doesn’t seem to work.
                        Sam 0 @MMRIZE
                        @MMRIZE
                        I also tested your code and it works fine too.
                          MMRIZE @Sam 0
                          @Sam-0
                          If you have some knowledge about CSS, you can almost control the look of this module. Most needed info is described in readme md file.
                            MMRIZE @Sam 0
                            @Sam-0 said in MMM-CalendarExt3 how do you create multiple events with color css?:
                            That is why I said;
                            First,
                            You can assign colour or class per each calendar. So check if your events are separated by different calendars. Check it first.
                            BKeyportB S 2 Replies Last reply Reply Quote 0
                            • BKeyportB Offline
                              BKeyport Module Developer @MMRIZE
                              Here’s my multi-transform code for reference. (The brackets may be off, I didn’t check on copy…)
                              					if (ev.title.search("🏠") > -1) {
                              						ev.title = ev.title.replace("🏠 Personal Commitment","🏠 Personal Event");
                              						ev.color = 'yellow';
                              					if (ev.title.search("✈ Flight") > -1) {
                              						ev.title = ev.title.replace("✈ Flight","🏠 Personal Event");
                              					if (ev.title.search("busy") > -1) {
                              						ev.title = ev.title.replace("busy","🏠 Mom Event");
                              					if (ev.title.search("Weekley") > -1) {
                              						ev.title = ev.title.replace("Weekley","Weekly");
                              					return ev
                              I’m using both CX3 and CX3A
                                Sam 0 @MMRIZE
                                First,
                                I only have one calendar. I’ve already looked at an example but it doesn’t seem to work.
                                I found this example on this forum.
                                with customer.css
                                .CX3 .Ben {
                                color: brown;
                                eventTransformer: function(ev) {
                                  if (ev.title.search(“Ben”) > -1)  ev.className = “Ben”;
                                  return ev
                                This doesn’t seem to do much, the color just remains white.
                                But is this possible?
                                  sdetweil @Sam 0
                                  @Sam-0 in the default calendar, where you put url:
                                  add
                                  color: … whatever
