    MMM-CalendarExt3 how do you create multiple events with color css?
    17 Posts 4 Posters 6.0k Views 4 Watching
      Sam 0 @MMRIZE
      @MMRIZE
      Thanks for your help, it went wrong at first because a bracket was missing.) I adjusted this but unfortunately it doesn’t work. Could this be related to the fact that I have already adjusted the CSS?
        module: "MMM-CalendarExt3",
        position: "lower_third",
        title: "",
             eventTransformer: (ev) => {
                    if (ev.title.search('Uitje') > -1) ev.color = 'blue'
                    if (ev.title.search('Verjaardag') > -1) ev.icon = 'birthday-cake'
                    return ev
        sdetweil @Sam 0
        @Sam-0 I’ve edited your post…
        please try to include all the braces {}
        so it is completely clear
        and use indents to add clarity to what is where …
          Sam 0 @MMRIZE
          @MMRIZE
          I have removed the custom CSS so it is standard, but I do not see the icon but I do see the blue color.
            MMRIZE @Sam 0
            @Sam-0 sorry, it would not be ‘icon’, it would be ’ symbol’
              Sam 0 @MMRIZE
              @MMRIZE
              So I see that Outing has turned blue, but I don’t see any other symbol for birthday.
                sdetweil @Sam 0
                @Sam-0 note the code should use symbol NOT icon
                  MMRIZE @Sam 0
                  @Sam-0
                  Sorry, the Previous version was not tested, I have shown the code only with my brain, not with a real device.
                  Here is the tested code.
                      if (ev.title.search('Uitje') > -1) ev.color = 'gold'
                      if (ev.title.search('Verjaardag') > -1) ev.symbol = ['birthday-cake']
                      return ev
                    Sam 0 @MMRIZE
                    @MMRIZE
                    Thank you very much for your effort. I try to describe as best as I can what is working now so that others can learn from it.
                    Okay, I did some further research based on the term symbol and saw that the symbols had to be added in the general calendar. I also saw them in MMM-CalendarExt3 as below.
                    Will show my config code here:
                    			header: "Familie agenda",
                    						symbol: "calendar-check",
                    						url: "outlook url"
                    customEvents: [
                        	{keyword: "zwemmen", symbol: "person-swimming fas fa-fw fa-person-swimming"},
                        	{keyword: "padel", symbol: "running fas fa-fw fa-running"},
                    	{keyword: "zingen", symbol: "music fas fa-fw fa-music"},
                    	{keyword: "verjaardag", symbol: "cake-candles fas fa-fw fa-cake-candles"},
                        	{keyword: "volleybal", symbol: "volleyball fas fa-fw fa-volleyball"}
                      title: "",
                       if (ev.title.search('Verjaardag') > -1) ev.color = '#FF69B4'
                    I will also try your previous code.
                    I would also like to control the color via CSS in the config file.
                    How are you doing this? I already tried something but this doesn’t seem to work.
                      Sam 0 @MMRIZE
                      @MMRIZE
                      I also tested your code and it works fine too.
                        MMRIZE @Sam 0
                        @Sam-0
                        If you have some knowledge about CSS, you can almost control the look of this module. Most needed info is described in readme md file.
                          MMRIZE @Sam 0
                          @Sam-0 said in MMM-CalendarExt3 how do you create multiple events with color css?:
                          That is why I said;
                          First,
                          You can assign colour or class per each calendar. So check if your events are separated by different calendars. Check it first.
                          BKeyportB S 2 Replies Last reply Reply Quote 0
                          • BKeyportB
                            BKeyport Module Developer @MMRIZE
                            Here’s my multi-transform code for reference. (The brackets may be off, I didn’t check on copy…)
                            					if (ev.title.search("🏠") > -1) {
                            						ev.title = ev.title.replace("🏠 Personal Commitment","🏠 Personal Event");
                            						ev.color = 'yellow';
                            					if (ev.title.search("✈ Flight") > -1) {
                            						ev.title = ev.title.replace("✈ Flight","🏠 Personal Event");
                            					if (ev.title.search("busy") > -1) {
                            						ev.title = ev.title.replace("busy","🏠 Mom Event");
                            					if (ev.title.search("Weekley") > -1) {
                            						ev.title = ev.title.replace("Weekley","Weekly");
                            					return ev
                            I’m using both CX3 and CX3A
                              Sam 0 @MMRIZE
                              @MMRIZE said in MMM-CalendarExt3 how do you create multiple events with color css?:
                              First,
                              I only have one calendar. I’ve already looked at an example but it doesn’t seem to work.
                              I found this example on this forum.
                              with customer.css
                              .CX3 .Ben {
                              color: brown;
                              eventTransformer: function(ev) {
                                if (ev.title.search(“Ben”) > -1)  ev.className = “Ben”;
                                return ev
                              This doesn’t seem to do much, the color just remains white.
                              But is this possible?
                                sdetweil @Sam 0
                                @Sam-0 in the default calendar, where you put url:
                                add
                                color: … whatever
