    MMM-weatherforecast not working correct, or?
    5 Posts 2 Posters 1.0k Views 2 Watching
      Manino
      Am I supposed to see days in this wheater view in the middle? There is only weather, no days. I have also tried to change the maxNumberOfDays but there is no change.
      I have tried to change the scale also, the forecast are outside my screen. I have set width in region third to 80% instead of 100% but there is no difference.
        Manino @sdetweil
        @sdetweil I did change weather module and first it did’nt work. But after a while it did. Think it was the 3.0 onecall api take some time after I did sign up. Thanks for the tip!
          sdetweil @Manino
          @Manino can you show the weather module config… xxxx out any api key, but don’t change the rest…
          some of the providers don’t give limited data on a free apikey…
          looks like you may have 2 modules? or the content wraps and causes the big space…
            Manino @sdetweil
            Yes, they are 2 modules, the top_right is MMM-OpenmapWeather.
            Hm ok so there can be limited data. This is my config and there is no difference if i take those out (I put them in by myself)
            showRainAmount: true,
            maxNumberOfDays: 8,
            scale: “50%”,
            	module: "MMM-weatherforecast",
            	position: "middle_center",
            	header: "Vädret i",	// This can be any of the regions.
            	         		// Best results in bottom_bar region due to horizontal default layout and icon sizes.
                maxNumberOfDays: 8,
                scale: "50%",
            		locationID: "", //Location ID from http://openweathermap.org/help/city_list.txt
            		appid: "xxxx" //openweathermap.org API key.
              sdetweil @Manino
              @Manino you may have to use apiVersion: “3.0” and sign up for the openaweathermap 3.0 onecall api … this module hasn’t been updated in 5 years…
                Manino @sdetweil
