upgrade 2.24 to 2.25 on arch linux - broken
7 Posts 3 Posters 1.3k Views 3 Watching
  • V Offline
    voodoo-magic
    Hello everyone,
    after updating to Version 2.25, MM no longer starts.
    Thank you in advance for any help.
    uname -a
    Linux archpi4 6.1.54-2-rpi-ARCH #1 SMP Fri Sep 29 12:55:29 MDT 2023 armv7l GNU/Linux
    lsb_release -a
    LSB Version:    n/a
    Distributor ID: Arch
    Description:    Arch Linux
    Release:        rolling
    Codename:       n/a
    pm2 stop all
    [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
    [PM2] [mm](0) ✓
    │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
    │ 0  │ mm                 │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
    npm start
    > magicmirror@2.25.0 start
    [03.10.2023 13:38.22.431] [LOG]   Starting MagicMirror: v2.25.0
    [03.10.2023 13:38.22.437] [LOG]   Loading config ...
    [03.10.2023 13:38.22.439] [DEBUG] config template file not exists, no envsubst
    [03.10.2023 13:38.22.443] [LOG]   Loading module helpers ...
    [03.10.2023 13:38.22.445] [LOG]   No helper found for module: alert.
    [03.10.2023 13:38.22.470] [LOG]   Initializing new module helper ...
    [03.10.2023 13:38.22.470] [LOG]   Module helper loaded: updatenotification
    [03.10.2023 13:38.22.471] [LOG]   No helper found for module: clock.
    [03.10.2023 13:38.22.472] [LOG]   No helper found for module: calendar_monthly.
    [03.10.2023 13:38.22.473] [LOG]   No helper found for module: compliments.
    [03.10.2023 13:38.22.474] [LOG]   No helper found for module: weather.
    [03.10.2023 13:38.22.478] [ERROR] (node:916) UnhandledPromiseRejectionWarning: Error: Cannot find module 'node-fetch'
    Require stack:
    - /home/michael/MagicMirror/modules/MMM-DWD-WarnWeather/node_helper.js
    - /home/michael/MagicMirror/js/app.js
    - /home/michael/MagicMirror/js/electron.js
    - /home/michael/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
        at node:internal/modules/cjs/loader:1084:15
        at Function.<anonymous> (node:electron/js2c/browser_init:2:117419)
        at Module._resolveFilename (/home/michael/MagicMirror/node_modules/module-alias/index.js:49:29)
        at node:internal/modules/cjs/loader:929:27
        at Function._load (node:electron/js2c/asar_bundle:2:13327)
        at Module.require (node:internal/modules/cjs/loader:1150:19)
        at require (node:internal/modules/cjs/helpers:110:18)
        at Object.<anonymous> (/home/michael/MagicMirror/modules/MMM-DWD-WarnWeather/node_helper.js:12:15)
        at Module._compile (node:internal/modules/cjs/loader:1271:14)
        at Object..js (node:internal/modules/cjs/loader:1326:10)
        at Module.load (node:internal/modules/cjs/loader:1126:32)
        at node:internal/modules/cjs/loader:967:12
        at loadModule (/home/michael/MagicMirror/js/app.js:180:19)
    (Use `electron --trace-warnings ...` to show where the warning was created)
    [03.10.2023 13:38.22.479] [ERROR] (node:916) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
    S 2 Replies Last reply Oct 3, 2023, 12:17 PM Reply Quote 0
      sdetweil @voodoo-magic
      @voodoo-magic did u upgrade node to at least v18?
      it is required
        @voodoo-magic said in upgrade 2.24 to 2.25 on arch linux - broken:
        Cannot find module ‘node-fetch’
        this was removed from the base on this release as we use the builtin fetch in v18 and above
        see
        • V Offline
          voodoo-magic
          $ node -v
          v20.8.0
          $ npm -v
          10.1.0
          Thank you very much for the answer, but what I have to do in the module MMM-DWD-WarnWeather?
          npm init -y?
          S 1 Reply Last reply Oct 3, 2023, 8:19 PM Reply Quote 0
            @voodoo-magic read the instructions… there are only 4 steps…
              rabbit83ka
              MMM-DWD-WarnWeather is now fixed.
              V 1 Reply Last reply Oct 4, 2023, 4:54 PM Reply Quote 0
              • V Offline
                voodoo-magic @rabbit83ka
                Thank you! @rabbit83ka @sdetweil
